Starting today, you can use the console to aggregate AWS Trusted Advisor recommendations across all accounts in your organization with AWS Organizations. The new Organizational View feature in Trusted Advisor allows you to generate reports with detailed check results across multiple accounts in your AWS organization. In addition, you can view a high level summary of check status within the console.
