Hashicorp Posted September 29, 2020 Share Posted September 29, 2020 Traditionally, developers looking to safely provision infrastructure using Terraform are given their own set of long-lived, scoped AWS credentials. While this enables the developer's freedom, using long-lived credentials can be dangerous and difficult to secure.Long-lived credentials on a developer's local machine create a large attack surface area. If a malicious actor gains access to the credentials, they could use them to damage resources.Operators need to manage a large number of static, long-lived AWS IAM credentials with varying scope.The new tutorial, Inject secrets into Terraform using the Vault provider, will guide you through storing your long-lived AWS credentials in Vault's AWS Secrets Engine, then leveraging Terraform's Vault provider to generate appropriately scoped & short-lived AWS credentials to be used by Terraform to provision resources in AWS.By using Vault, developers can provision resources without direct access to secrets. Operators are able to manage permissions by modifying a Vault role’s policy, instead of juggling static, long-lived secrets with varying scope. By the end of this tutorial, you will understand how to use Vault to inject secrets into Terraform configuration, and the benefits and considerations of using this approach. View the full article Quote Link to comment Share on other sites More sharing options...
