TomsHardware Posted April 9 Share Posted April 9 Hyte’s THICC Q60 is the best-performing 240mm AIO we’ve tested, and it's loaded with features like a large screen. But it’s also extremely expensive and, as the name implies, it’s very chunky, so it won’t fit in every case that has room for a typical 240mm AIO. View the full article Quote Link to comment Share on other sites More sharing options...
