DevOpsSchool Posted March 30 Share Posted March 30 List of all command with options for /opt/lampp/lampp sudo /opt/lampp/lampp start # Start XAMPP (Apache, MySQL, and any other services included) sudo /opt/lampp/lampp stop # Stop XAMPP sudo /opt/lampp/lampp restart # Restart XAMPP sudo /opt/lampp/lampp startapache # Start only the Apache service sudo /opt/lampp/lampp stopapache # Stop the Apache service sudo /opt/lampp/lampp startmysql # Start only the MySQL/MariaDB service sudo /opt/lampp/lampp stopmysql # Stop the MySQL/MariaDB service sudo /opt/lampp/lampp startftp # Start the ProFTPD service sudo /opt/lampp/lampp stopftp # Stop the ProFTPD service sudo /opt/lampp/lampp security # Run a simple security check script sudo /opt/lampp/lampp enablessl # Enable SSL support for Apache sudo /opt/lampp/lampp disablessl # Disable SSL support for Apache sudo /opt/lampp/lampp backup # Create a simple backup of your XAMPP configuration, data, and logs sudo /opt/lampp/lampp status # Show status of XAMPP services sudo /opt/lampp/lampp reload # Reload XAMPP (Apache and MySQL reload configuration without stopping the server) sudo /opt/lampp/lampp reloadapache # Reload only the Apache service sudo /opt/lampp/lampp reloadmysql # Reload only the MySQL/MariaDB service sudo /opt/lampp/lampp reloadftp # Reload the ProFTPD service sudo /opt/lampp/lampp enablephpmyadmin # Enable phpMyAdmin access from network (modify permissions) sudo /opt/lampp/lampp disablephpmyadmin# Disable phpMyAdmin access from network sudo /opt/lampp/lampp phpstatus # Show PHP status (e.g., for checking PHP-FPM status) sudo /opt/lampp/lampp clean # Clean XAMPP (clears temporary files and logs) The post Lampp commands line reference with example appeared first on DevOpsSchool.com. View the full article Quote Link to comment Share on other sites More sharing options...
