TechRadar Posted March 13 Share Posted March 13 The Google Contacts app is getting an update that'll streamline its user interface, as well as a new widget that could help you avoid missing important messages by placing them front and center. According to code deep dive by AssembleDebug, the update includes a widget that will show messages from contacts on your phone’s home screen. This should make them harder to miss, even if notifications are off and the phone is silenced.Users will still need to allow permission for such alerts by tapping the notification icon on the top right of the widget. This will then prompt a dialog box that will explain the feature and request permission.It’s thought that the widget will only show messages from a single contact, and will include the options to allow users to reply or call them back.The update could make it easier to find contacts. Changes to the Contacts home screen have removed the ‘Phone contacts’, ‘Email contacts’, and ‘Company filters’ from the top of the screen. This declutters the page, and these options have been moved to the main menu (three horizontal bars), and appear at the bottom of the screen, so they can still be accessed if needed. (Image credit: AssembleDebug / TheSpAndroid) Another UI change simplifies how the app shows calls and contact details from other apps like WhatsApp, and Telegram. Instead of displaying a confusing list of entries, including missed and connected calls and messages, the new update adds a 'Connected app’ section that lists the third-party apps with drop-down menus for users to pursue notifications about calls and messages.The changes aren’t just limited to WhatsApp and Telegram contacts, as more messaging apps will also appear in this list if they are installed. Google Contacts simplifies showing your contact's numbers from other apps Read - https://t.co/Y8ZIFVo7lm#Google #Android pic.twitter.com/M0pNDSvxuJMarch 10, 2024See more The image on the left displays the more cluttered, older interface while the image on the right displays the newer more organized look.Google Contacts is a free, built-in app for many Android phones including the Google Pixel lineup that allows users to manage their phone numbers and contacts, so any changes will affect a significant number of users. It’s not known when these features will roll out – assuming Google decides to release them – and they’re currently hidden behind flags, meaning they’re unavailable for the public until implemented on Google's server side. However, you’ll likely need to have the latest version of Contacts, version 4.26 to see the features, and after that, you should receive the update as soon as it is rolled out. While the updates aren’t exactly revolutionary, any changes making our phones easier to use are welcome. However, if you want to try something completely different then take a look at our best iPhones list. You may also like Google’s ‘affordable’ Pixel 8a may not be so affordable after allGoogle’s experimental feature could give one of the Pixel’s best tools to everyoneAndroid 15: latest news, rumors, and everything we know so far View the full article Quote Link to comment Share on other sites More sharing options...
