DZone Posted March 9 Share Posted March 9 Connecting AWS Lambda to an AWS RDS instance allows you to build serverless applications that can interact with relational databases, thereby enabling you to manage database operations without provisioning or managing servers. This comprehensive guide walks you through the process of setting up AWS Lambda to connect to an RDS instance and write data to tables, step-by-step. Prerequisites Before we dive into the steps, ensure you have the following prerequisites covered:View the full article Quote Link to comment Share on other sites More sharing options...
