TomsHardware Posted March 5 Share Posted March 5 JEDEC has published the specifications for the GDDR7 memory standard, which will likely replace GDDR6 memory in the next-generation GPUs when they arrive next year. As you might expect, there will be higher speeds and bandwidth, up to 192 GB/s per device. View the full article Quote Link to comment Share on other sites More sharing options...
