TomsHardware Posted March 3 Share Posted March 3 To achieve a fuzzy surface on 3D prints, you need to use Cura’s Fuzzy Skin feature. Get to know how to use this setting to enhance the appearance of your prints. View the full article Quote Link to comment Share on other sites More sharing options...
