Linux Hint Posted February 22 Share Posted February 22 Python is a weakly typed interpreted language. So, the data type declaration is not required in Python for the variable declaration. Different types of data are supported by the Python script. The string data is one of them. The string data is used to store multiple characters. The methods of defining and using the string data in Python are shown in this tutorial. Topic of Contents: Define the String Variables Count the Length of the String Print the String Format the String Remove the Content from a String Split the String Trim the String Reverse the String Replace the String Value Change the Case of the String Define the String Variables The string value can be defined in three ways in the Python script: the single quotes (‘), double quotes (“), and triple quotes (”’). Create a Python file with the following script that defines three string variables and print the variables in the output: #Define variable with single quotes to store single-line string string1 = 'Python programming' #Define variable with double quotes to store single-line string string2 = "Python is a weakly typed language" #Define variable with triple quotes to store multi-line string string3 = '''Learn Python programming from the basic''' #Print the variables print(string1) print(string2) print(string3) Output: The following output appears after executing the script: Go to top Count the Length of the String Python has a built-in function named len() to count the length of the string variable. Create a Python file with the following script that takes a string value from the user, the print input value, and the length of the input value: #Take a string value strVal = input("Enter a string value: ") #Count the total characters of the input value ln = len(strVal) #Print the string value taken from user print ("The string value is:", strVal) #Print the length of the string print ("The length of the string is:", ln) Output: According to the following output, “Python String” is taken from the user as an input value. The length of this string is 13 which is printed: Go to top Print the String Create a Python file with the following script that shows the methods of printing a single string value, one numeric and one string value, one variable with another string, and multiple variables with other strings. Three input values are taken from the user after executing the script. #Print single value print ("Learn Python") #Print multiple values print (15, " Python String Examples") #Take three input values from the user course_code = input("Enter the course code:") course_name = input("Enter the course name:") credit_hour = float(input("Enter the credit hour:")) #Print a single variable print ("\n","Course Code:", course_code) #Print multiple variables print (" Course Name:", course_name, "\n","Credit Hour:", credit_hour) Output: “CSE320”, “Python Programming”, and “2.0” are taken as input after executing the script. These values are printed later. Go to top Format the String Multiple options are available in Python to format the string values. The format() function is one of them. Different ways of using the format() function in the Python script are shown in the following script. The student name and the batch are taken from the user after executing the script. Next, these values are printed with other strings using the format() function with the key values and positional values. #Take a string value from the user name = input("Student name:") #Take a number value from the user batch = int(input("Batch:")) #Use of format() function with the variables print ("{n} is the student of {b} batch.".format(n = name, b = batch)) #Use of format() function with one string value and one numeric value print ("{n} is the student of {s} semester.".format(n = "Jafar", s = 6)) #Use of format() function without defining positional keys print ("{} is the student of {} batch.".format(name, 12)) #Use of format() function by defining numeric positional keys print ("{1} is the student of {0} semester.".format(10,"Mazhar")) Output: The following output appears for the input values, “Mizanur Rahman” as the student name and 45 as the batch value: Go to top Remove the Content from a String The partial content or the full content of a string variable can be removed from the Python string variable. Create a Python file with the following script that takes a string value from the user. Next, the script removes the content of the input value partially by cutting the string like the previous example and making the undefined variable using the “del” command. try: #Take a string value strVal = input("Enter a string value:\n") print ("Original string:" + strVal) #Remove all characters from the string after #the first 10 characters strVal = strVal[0:10] print ("String value after first delete:" + strVal) #Remove 5 characters from the beginning of the string strVal = strVal[5:] print ("String value after second delete:" + strVal) #Remove the particular character from the string if exists strVal = strVal.replace('I', '', 1) print ("String value after third delete:" + strVal) #Remove the entire string and make the variable undefined del strVal print ("String value after last delete:" + strVal) except NameError: #Print the message when the variable is undefined print ("The variable is not defined.") Output: The following output appears after executing the script: Go to top Split the String Create a Python file with the following script that splits the string value based on the space, colon (:), a particular word, and the maximum limit: #Take a string value from the user strVal = input("Enter a string value:\n") #Split the string without any argument print ("Split values based on the space:") print (strVal.split()) #Split the string based on a character print ("Split values based on the ':' ") print (strVal.split(':')) #Split the string based on a word print ("Split values based on the word ") print (strVal.split('course')) #Split the string based on the space and the maximum limit print ("Split values based on the limit ") print (strVal.split(' ', 1)) Output: The following output appears for the “course code: CSE – 407” input value after executing the script: Go to top Trim the String Create a Python file with the following script that trims the string based on the space from both sides, left side, and right side using the strip(), lstrip(), and rstrip() functions. The last lstrip() function is used based on the “P” character. strVal = " Python is a popular language. " print ("Original string:" + strVal) #Trim both sides strVal1 = strVal.strip() print ("After trimming both sides: " + strVal1) #Trim left side strVal2 = strVal.lstrip() print ("After trimming left side: " + strVal2) #Trim right side strVal3 = strVal.rstrip() print ("After trimming right side: " + strVal3) #Trim left side based on a character strVal4 = strVal2.lstrip('P') print ("After trimming left side based on a character: " + strVal4) Output: The following output appears after executing the script: Go to top Reverse the String Create a Python file with the following script that reverses the value of the string value by setting the start position at the end of the string with the -1 value: #Take a string value from the user strVal = input("Enter a string value:\n") #Store the reversed value of the string reverse_str = strVal[::-1] #Print both original and reversed values of the string print ("Original string value: " + strVal) print ("Reversed string value: " + reverse_str) Output: The following output appears for the “Hello World” input value: Go to top Replace the String Value Create a Python file with the following script that takes the main string, search string, and the replace string from the user. Next, the replace() function is used to search and replace the string. #Take the main string strVal = input("Enter a string value:\n") #Take the search string srcVal = input("Enter a string value:\n") #Take the replaced string repVal = input("Enter a string value:\n") #Search and replace the string replaced_strVal = strVal.replace(srcVal, repVal) #Print the original and replaced string values print ("Original string:" + strVal) print ("Replaced string:" + replaced_strVal) Output: The following output appears for the “Do you like PHP?” main string value, the “PHP” search value, and the “Python” replacement value: Go to top Change the Case of the String Create a Python file with the following script that takes the email address and password from the user. Next, the lower() and upper() functions are used to compare the input values with the particular values to check if the input values are valid or invalid. #Take the email address email = input("Enter email address:") #Take the password password = input ("Enter the password:") #Compare the string values after converting the email #in lowercase and password in uppercase if email.lower() == "admin@example.com" and password.upper() == "SECRET": print ("Authenticated user.") else: print ("Email or password is wrong.") Output: The following output appears for the “admin@example.com” and “secret” input values: The following output appears for the “admin@abc.com” and “secret” input values: Go to top Conclusion Different types of string-related tasks using different built-in Python functions are shown in this tutorial using multiple Python scripts. The Python users will now be able to get the basic knowledge of the Python string operations after reading this tutorial properly. View the full article Quote Link to comment Share on other sites More sharing options...
