Docker Posted February 20 Share Posted February 20 This post was contributed by BastionZero. Giving people the ability to sign messages under their identity is extremely powerful. For instance, this functionality lets you SSH into servers, sign software artifacts, and create end-to-end encrypted communications under your single sign-on (SSO) identity. The OpenPubkey protocol and open source project brings the power of digital signatures to both people and workloads without adding trusted parties. OpenPubkey is built on the OpenID Connect (OIDC) SSO protocol, which is supported by major identity providers, including Google, Microsoft, Okta, and Facebook. This article will explore how OpenPubkey works and look at three use cases in detail. What can OpenPubkey do? Public key cryptography was invented in the 1970s and has become the most powerful tool in the security engineering toolbox. It allows anything holding a public key, and its associated signing key, to create a cryptographic identity. This identity is extremely secure because the party cannot only use their signing key to prove they are who they say they are but also sign messages under this identity. Servers often authenticate themselves to people using public keys associated with the server’s identity, yet the process rarely works the other way. People rarely authenticate to servers using public keys associated with a person’s identity. Instead, less secure authentication methods are employed, such as authentication secrets stored in cookies, which must be transmitted on every request.Let’s say that Alice wanted to sign the message “Flee at once — all is discovered” under her email address alice@example.com. How would she do it? One approach would be for Alice to create a public key (PK) and signing key (SK) and then publish the mapping between her email and the PK. This approach has two problems. First, you and everyone verifying this message must trust that the webpage has honestly mapped Alice’s email to her public key and has not maliciously replaced her public key with another key that could be used to impersonate Alice. Second, Alice must now protect and manage the signing key associated with this public key. History has shown that users can be terrible at protecting signing keys. Probably the most famous example is of the man who lost a signing key controlling half a billion dollars worth of Bitcoin.Human authentication on the web was originally supposed to work the same way as server authentication. Much like a certificate authority (CA) issues a certificate to a server, which associates a public key with the server’s identity (`example.com`), the plan was to have a CA issue a client certificate to a person that associates a public key with that person’s identity. These client certificates are still around and are well-used for certain applications, but they never caught on for widespread personal use, likely because of the terrible user experience (UX) of asking people to secure and manage secret signing keys.OpenPubkey addresses both of these problems. It uses your identity provider to perform the mapping between identity and your public key. Because you already trust your identity provider, having your identity provider perform this mapping does not add any new trusted parties. For instance, Alice must already trust her identity provider, Example.com, to manage her identity (alice@example.com), so it is natural to use Example.com to perform the mapping between Alice’s public key and her Example.com identity (alice@example.com). Example.com already knows how to authenticate @example.com users, so Alice doesn’t need to set up a new account or create new authentication factors.Second, to solve the problem of lost or stolen signing keys, OpenPubkey public keys and signing keys are ephemeral. That means the signing keys can be deleted and recreated at will. OpenPubkey generates a fresh public key and signing key for a user every time that user authenticates to their identity provider. This approach to making public keys ephemeral removes one of the most significant UX barriers to authenticating people with public keys. It also provides a security win; it creates a much smaller window of exposure if a signing key is stolen, as signing keys can be deleted when the user idles or logs out. How does OpenPubkey work? Let’s return to our situation: Alice wants to sign the message “Flee at once — all is discovered” under her identity (alice@example.com). First, Alice’s computer generates a fresh public key and signing key. Next, she needs her identity provider, Example.com, to associate her identity with this public key. How does OpenPubkey do this? To understand the process, we first need to provide details about how SSO/OpenID Connect works.Example.com, which is the identity provider for @example.com, knows how to check that Alice is really alice@example.com. Example.com does this every time Alice signs into Example.com. In OIDC, the identity provider signs a statement, called an ID Token, which roughly says “this is alice@example.com”. Part of the authentication process in OIDC allows the user (or their software) to submit a random value that will be included in the issued ID Token. Alice’s OpenPubkey client puts the cryptographic hash of Alice’s public key into this value in her ID Token. Alice’s OpenPubkey client modifies the ID Token into an object called a PK Token, which essentially says: “this is alice@example.com and her public key is 0xABCE…“. We’re skipping a few details of OpenPubkey, but this is the basic idea. Now that Alice has a PK Token signed by Example.com, which binds her public key to her identity, she can sign the statement “Flee at once — all is discovered” and broadcast the message, the signature, and her ID Token. Bob, or anyone else for that matter, can check whether this message is really from alice@example.com, by checking that the ID Token is signed by Example.com and then checking that Alice’s signature matches the public key in the ID Token. OpenPubkey use cases Now let’s look at OpenPubkey use cases. SSH OpenPubkey is useful for more than just telling your friends that “Flee at once — all is discovered.” Because most security protocols are built on public key cryptography, OpenPubkey can easily plug human identities into these protocols. SSH supports the authentication of both machines and users with public keys (also known as SSH keys). However, these SSH keys are not associated with identities. With an SSH key, you can say “allow root access for key 0xABCD…”, but not “allow root access for alice@example.com.” This presents several UX and security problems. As mentioned previously, people struggle with managing their secret signing keys, and SSH is no exception. Even more problematic, because public keys are not associated with identities, it is difficult to tell if an SSH key represents a person or machine that should no longer have access. As Tatu Ylonen, the inventor of SSH, writes in his recent paper Challenges in Managing SSH Keys — and a Call for Solutions: “In analyzing SSH keys for dozens of large enterprises, it has turned out that in many environments 90% of all authorized keys are no longer used. They represent access that was provisioned, but never terminated when the person left or the need for access ceased to exist. Some of the authorized keys are 10-20 years old, and typically about 10% of them grant root access or other privileged access. The vast majority of private user keys found in most environments do not have passphrases.” OpenPubkey can be used to solve this problem by binding SSH keys to user identities. That way, the server can check whether the identity (alice@example.com) is allowed to connect to the server or not. This means that Alice can access her SSH server using SSO; she can log in to Example.com as alice@example.com and then gain access to the server as long as her SSO is valid.OpenPubkey authentication can be added to SSH with a small change to the SSH config. No code changes to SSH are required. To try it out, or learn more about how OpenPubkey’s SSH works, see our recent post: How to Use OpenPubkey to SSH Without SSH Keys. Secure messaging OpenPubkey can also be used to solve one of the major issues with end-to-end encrypted messaging. Suppose someone sends you a message on a secure messaging app: How do you know they are actually that person? Some secure messaging apps let you look up the public key that is securing your communication, but how do you know that that public key is actually the public key of the person you want to privately communicate with?This connection between public key and identity is the core problem that OpenPubkey solves. With OpenPubkey, Bob can learn the public key for alice@example.com by checking an ID Token signed by Example.com, which includes Alice’s public key and her email address. This does involve trusting Example.com, but you generally already have to trust Example.com to SSO @example.com users. While it’s not discussed here, OpenPubkey does support an optional protocol — the MFA cosigner — which removes the requirement of trusting the identity provider. But even without the MFA cosigner protocol, OpenPubkey provides stronger security for end-to-end encrypted messaging because it allows Bob to learn Alice’s public key directly from Alice’s identity provider. Signing container images OpenPubkey is not limited to human use cases. OpenPubkey developers are working on a solution to allow workflows (rather than people) to sign images using GitHub’s identity provider and GitHub Actions. You can learn more about this use case by reading How to Use OpenPubkey with GitHub Actions Workloads. Help us expand the utility of OpenPubkey These three use cases should not be seen as the limits of what OpenPubkey can do. This approach is highly flexible and can be used for VPNs, cosigning, container service meshes, cryptocurrencies, web applications, and even physical access. We invite anyone who wants to contribute to OpenPubkey to visit and star our GitHub repo. We are building an open and friendly community and welcome pull requests from anyone — see the contribution guidelines to learn more. Learn more Read How to Use OpenPubkey with GitHub Actions Workloads. Read How to use OpenPubkey to SSH Without SSH Keys. Fireside chat — Redefining Security Standards: Identity Providers as Certificate Authorities. Get the latest release of Docker Desktop. Vote on what’s next! Check out our public roadmap. Have questions? The Docker community is here to help. New to Docker? Get started. View the full article Quote Link to comment Share on other sites More sharing options...
