Linux Hint Posted February 16 Share Posted February 16 Tcpdump is a powerful network analysis tool that is used for network traffic analysis in Linux systems and macOS. Network administrators use tcpdump for network sniffing, capturing, and analyzing the TCP/IP packets. It uses a “libpcap” library that helps in capturing the network traffic efficiently. In addition, tcpdump helps in network troubleshooting and monitoring the network activities periodically. This tool stores the captured data in a “pcap” file. These files are further analyzed using a TCP/IP packet analyzer tool such as Wireshark or via another command line tool. In this guide, we will demonstrate how to install tcpdump on a Linux system and how to capture and analyze the TCP/IP packets using tcpdump. How to Install Tcpdump Tcpdump is preinstalled on many Linux distributions. But if it is not already installed on your system, you can install tcpdump on your Linux system. To install tcpdump on the Ubuntu 22.04 system, use the following command: $ sudo apt install tcpdump To install tcpdump on Fedora/CentOS, use the following command: $ sudo dnf install tcpdump How to Capture the Packets Using the Tcpdump Command To capture the packets with tcpdump, launch the terminal with sudo privileges using “Ctrl+Alt+t”. This tool includes different options and filters to capture the TCP/IP packets. If you want to capture all flowing packets of the current or default network interface, use the “tcpdump” command without any option. $ sudo tcpdump The given command captures the packets of the default network interface of your system. At the end of the execution of this command, all captured and filtered packet counts are displayed on the terminal. Let’s understand the output. Tcpdump enables the analysis of the TCP/IP packet headers. It shows a single line for each packet, and the command continues running until you press “Ctrl+C” to stop it. Each line provided by tcpdump contains the following details: Unix timestamp (e.g., 02:28:57.839523) Protocol (IP) Source hostname or IP and port number Destination hostname or IP and port number TCP Flags (e.g., Flags [F.]) indicating the connection state with values like S (SYN), F (FIN),. (ACK), P (PUSH), R (RST) Sequence number of the data in the packet (e.g., seq 5829:6820) Acknowledgment number (e.g., ack 1016) Window size (e.g., win 65535) representing the available bytes in the receiving buffer followed by TCP options Length of the data payload (e.g., length 991) To list all the list network interfaces of your system, use the “tcpdump” command with the “-D” option. $ sudo tcpdump -D or $ tcpdump --list-interfaces This command lists all the network interfaces that are connected or running on your Linux system. Capture the Packets of Specified Network Interface If you want to capture the TCP/IP packets that pass through a specific interface, use the “-i” flag with the “tcpdump” command and specify the network interface name. $ sudo tcpdump -i lo The given command captures the traffic at the “lo” interface. If you want to display a verbose or detailed information about the packet, use the “-v” flag. To print more comprehensive details, use the “-vv” flag with the “tcpdump” command. Regular use and analysis contribute to maintaining a robust and secure network environment. Similarly, you can capture the traffic at any interface using the following command: $ sudo tcpdump -i any Capture the Packets Using a Specific Port You can capture and filter the packets by specifying the interface name and port number. For example, to capture the network packets that pass through the “enp0s3” interface using port 22, use the following command: $ tcpdump -i enp0s3 port 22 The previous command captures all flowing packets from the “enp0s3” interface. Capture the Limited Packets with Tcpdump You can use the “-c” flag with the “tcpdump” command to capture a specified number of packets. For example, to capture four packets at the “enp0s3” interface, use the following command: $ tcpdump -i enp0s3 -c 4 Replace the interface name using your system. Useful Tcpdump Commands to Capture the Network Traffic In the following, we listed some useful “tcpdump” commands that will help you in capturing and filtering the network traffic or packets efficiently: Using the “tcpdump” command, you can capture the packets of an interface with a defined destination IP or source IP. $ tcpdump -i {interface-name} dst {destination-ip} You can capture the packets with a snapshot size of 65535 bytes which is different from the default size of 262144 bytes. In the older versions of tcpdump, the capture size was limited to 68 or 96 bytes. $ tcpdump -i enp0s3 -s 65535 How to Save the Captured Packets into a File If you want to save the captured data into a file for further analysis, you can do it. It captures the traffic at a specified interface and then saves it into a “.pcap” file. Use the following command to store the captured data into a file: $ tcpdump -i <interface-name> -s 65535 -w <file-name>.pcap For example, we have the “enps03” interface. Save this captured data into the following file: $ sudo tcpdump -i enps03 -w dump.pcap In the future, you can read this captured file using Wireshark or other network analysis tools. So, if you want to use Wireshark to analyze the packets, use the “-w” argument and save it into a “.pcap” file. Conclusion In this tutorial, we demonstrated how to capture and analyze the packets using tcpdump with the help of different examples. We also learned how to save the captured traffic into a “.pcap” file which you can view and analyze using Wireshark and other network analysis tools. View the full article Quote Link to comment Share on other sites More sharing options...
