DZone Posted June 7, 2018 Share Posted June 7, 2018 This article will demonstrate how to build a complete CI/CD pipeline in Visual Studio and deploy it to Azure using the new Continuous Delivery Extension for Visual Studio. Using CI allows you to merge the code changes in order to ensure that those changes work with the existing code base and allows you to perform testing. On the other hand, using CD, you are repeatedly pushing code through a deployment pipeline where it is built, tested, and deployed afterward. This CI/CD team practice automates the build, testing, and deployment of your application, and allows complete traceability in order to see code changes, reviews, and test results.View the full article Quote Link to comment Share on other sites More sharing options...
