Google Cloud Platform Posted January 26 Share Posted January 26 If you run workloads on Kubernetes, chances are you’ve experienced a “cold start”: a delay in launching an application that happens when workloads are scheduled to nodes that haven’t hosted the workload before and the pods need to spin up from scratch. The extended startup time can lead to longer response times and a worse experience for your users — especially when the application is autoscaling to handle a surge in traffic. What’s going on during a cold start? Deploying a containerized application on Kubernetes typically involves several steps, including pulling container images, starting containers, and initializing the application code. These processes all add to the time before a pod can start serving traffic, resulting in increased latency for the first requests served by a new pod. The initial startup time can be significantly longer because the new node has no pre-existing container image. For subsequent requests, the pod is already up and warm, so it can quickly serve requests without extra startup time. Cold starts are frequent when pods are continuously being shut down and restarted, as that forces requests to be routed to new, cold pods. A common solution is to keep warm pools of pods ready to reduce the cold start latency. However, with larger workloads like AI/ML, and especially on expensive and scarce GPUs, the warm pool practice can be very costly. So cold starts are especially prevalent for AI/ML workloads, where it’s common to shut down pods after completed requests. Google Kubernetes Engine (GKE) is Google Cloud’s managed Kubernetes service, and can make it easier to deploy and maintain complex containerized workloads. In this post, we’ll discuss four different techniques to reduce cold start latency on GKE, so you can deliver responsive services. Techniques to overcome the cold start challenge Use ephemeral storage with local SSDs or larger boot disks Nodes mount the Kubelet and container runtime (docker or containerd) root directories on a local SSD. As a result, the container layer is backed by the local SSD, with the IOPS and throughput documented on About local SSDs. This is usually more cost-effective than increasing the PD size. The following table compares the options and demonstrates that for the same cost, LocalSSD has ~3x more throughput than PD, allowing the image pull to run faster and reduce the workload’s startup latency. With the same cost LocalSSD PD Balanced Throughput Comparison $ per month Storage space (GB) Throughput(MB/s) R W Storage space (GB) Throughput (MB/s) R+W LocalSSD / PD (Read) LocalSSD / PD (Write) $ 375 660 350 300 140 471% 250% $$ 750 1320 700 600 168 786% 417% $$$ 1125 1980 1050 900 252 786% 417% $$$$ 1500 2650 1400 1200 336 789% 417% You can create a node pool that uses ephemeral storage with local SSDs in an existing cluster running on GKE version 1.25.3-gke.1800 or later. code_block <ListValue: [StructValue([('code', 'gcloud container node-pools create POOL_NAME \\\r\n --cluster=CLUSTER_NAME \\\r\n --ephemeral-storage-local-ssd count=<NUMBER_OF_DISKS> \\\r\n --machine-type=MACHINE_TYPE'), ('language', ''), ('caption', <wagtail.rich_text.RichText object at 0x3e4b3ed176d0>)])]> For more, see Provision ephemeral storage with local SSDs.2. Enable container image streamingImage streaming can allow workloads to start without waiting for the entire image to be downloaded, leading to significant improvements in workload startup time. For example, with GKE image streaming, the end-to-end startup time (from workload creation to server up for traffic) for an NVIDIA Triton Server (5.4GB container image) can be reduced from 191s to 30s.You must use Artifact Registry for your containers and meet the requirements. Image Streaming can be enabled on the cluster by code_block <ListValue: [StructValue([('code', 'gcloud container clusters create CLUSTER_NAME \\\r\n --zone=COMPUTE_ZONE \\\r\n --image-type="COS_CONTAINERD" \\\r\n --enable-image-streaming'), ('language', ''), ('caption', <wagtail.rich_text.RichText object at 0x3e4b3ed17bb0>)])]> To learn more, see Use Image streaming to pull container images.3. Use Zstandard compressed container imagesZstandard compression is a feature supported in ContainerD. Zstandard benchmark shows zstd is >3x faster decompression than gzip (the current default). Here’s how to use the zstd builder in docker buildx: code_block <ListValue: [StructValue([('code', 'docker buildx create --name zstd-builder --driver docker-container \\\r\n --driver-opt image=moby/buildkit:v0.10.3\r\ndocker buildx use zstd-builder'), ('language', ''), ('caption', <wagtail.rich_text.RichText object at 0x3e4b3ed17c40>)])]> Here’s how to build and push an image: code_block <ListValue: [StructValue([('code', 'IMAGE_URI=us-central1-docker.pkg.dev/taohe-gke-dev/example\r\nIMAGE_TAG=v1\r\n\r\n<Create your Dockerfile>\r\n\r\ndocker buildx build --file Dockerfile --output type=image,name=$IMAGE_URI:$IMAGE_TAG,oci-mediatypes=true,compression=zstd,compression-level=3,force-compression=true,push=true .'), ('language', ''), ('caption', <wagtail.rich_text.RichText object at 0x3e4b3ed17640>)])]> Please note that Zstandard is incompatible with image streaming. If your application requires the majority of the container image content to be loaded before starting, it’s better to use Zstandard. If your application needs only a small portion of the total container image to be loaded to start executing, then try image streaming.4. Use a preloader DaemonSet to preload the base container on nodesLast but not least, ContainerD reuses the image layers across different containers if they share the same base container. And the preloader DaemonSet can start running even before the GPU driver is installed (driver installation takes ~30 seconds). That means it can preload required containers before the GPU workload can be scheduled to the GPU node and start pulling images ahead of time.Below is an example of the preloader DaemonSet. code_block <ListValue: [StructValue([('code', 'apiVersion: apps/v1\r\nkind: DaemonSet\r\nmetadata:\r\n name: container-preloader\r\n labels:\r\n k8s-app: container-preloader\r\nspec:\r\n selector:\r\n matchLabels:\r\n k8s-app: container-preloader\r\n updateStrategy:\r\n type: RollingUpdate\r\n template:\r\n metadata:\r\n labels:\r\n name: container-preloader\r\n k8s-app: container-preloader\r\n spec:\r\n affinity:\r\n nodeAffinity:\r\n requiredDuringSchedulingIgnoredDuringExecution:\r\n nodeSelectorTerms:\r\n - matchExpressions:\r\n - key: cloud.google.com/gke-accelerator\r\n operator: Exists\r\n tolerations:\r\n - operator: "Exists"\r\n containers:\r\n - image: "<CONTAINER_TO_BE_PRELOADED>"\r\n name: container-preloader\r\n command: [ "sleep", "inf" ]'), ('language', ''), ('caption', <wagtail.rich_text.RichText object at 0x3e4b3ed17160>)])]> Outsmarting the cold startThe cold start challenge is a common problem in container orchestration systems. With careful planning and optimization, you can mitigate its impact on your applications running on GKE. By using ephemeral storage with larger boot disks, enabling container streaming or Zstandard compression, and preloading the base container with a daemonset, you can reduce cold start delays and ensure a more responsive and efficient system. To learn more about GKE, check out the user guide.View the full article Quote Link to comment Share on other sites More sharing options...
