samcullin Posted January 1 Share Posted January 1 I am new to AWS, can someone tell me how to connect to AWS. Quote Link to comment Share on other sites More sharing options...
Simon Posted April 1 Share Posted April 1 Hi Sam, For general information about getting started on AWS the resources here are useful https://aws.amazon.com/getting-started/ Regarding connecting to your AWS instance from your computer, this depends on a couple of factors: Your Operating System: The process differs slightly between Windows and MacOS/Linux systems. Security Group Configuration: Your instance's security group needs to allow SSH access from your computer's IP address. Here's a general breakdown of the steps involved: 1. Prerequisites: Public IP or DNS Name: You'll need the public IP address or DNS name of your EC2 instance. You can find this in the EC2 console on the AWS web interface. SSH Key Pair: You'll most likely be using SSH to connect. If you haven't already, create a key pair and download the private key file (.pem) to your computer. 2. Connecting with SSH: Windows: There are a few options. You can use PuTTY, a free SSH client, along with your downloaded private key file. MacOS/Linux: These systems typically have SSH built-in. You can use the terminal app and the ssh command. 3. Specific Steps: The specific steps for using SSH will depend on your OS and chosen tool (PuTTY for Windows). In general, the SSH command will follow this format: ssh -i "path/to/your/privateKey.pem" username@ipAddress Replace "path/to/your/privateKey.pem" with the actual location of your downloaded private key file. Replace "username" with the username you specified when launching the EC2 instance (often ubuntu). Replace "ipAddress" with the public IP address or DNS name of your instance. Here are some resources that can help you with the specific steps: AWS Documentation on Connecting to EC2 Instances: https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/connect-linux-inst-ssh.html Video Tutorial on Connecting to EC2 from Windows: [YouTube connect to ec2 instance windows] By following these steps and referencing the provided resources, you should be able to connect to your AWS instance from your computer. Quote Link to comment Share on other sites More sharing options...
