DevOpsSchool Posted December 5, 2023 Share Posted December 5, 2023 Install AWS CLi in CENTOS/RHEL $ sudo yum remove awscli Install AWS CLi in Ubuntu $ sudo apt-get install awscli Install AWS CLi in Linux using Package curl "https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip" -o "awscliv2.zip" unzip awscliv2.zip sudo ./aws/install sudo ./aws/install --bin-dir /usr/local/bin --install-dir /usr/local/aws-cli --update which aws ls -l /usr/local/bin/aws aws --version Install AWS CLi in Windows DOWNLOAD - https://awscli.amazonaws.com/AWSCLIV2.msi msiexec.exe /i https://awscli.amazonaws.com/AWSCLIV2.msi msiexec.exe /i https://awscli.amazonaws.com/AWSCLIV2.msi /qn aws --version Configure AWS and Verify Login $ aws configure AWS Access Key ID [None]: your-access-key-id AWS Secret Access Key [None]: your-secret-access-key Default region name [None]: region-to-use (e.g us-west-2, us-west-1, etc). Default output format [None]: $ aws s3 ls The post AWS Tutorials: Install and Configure AWS CLI appeared first on DevOpsSchool.com. View the full article Quote Link to comment Share on other sites More sharing options...
