DevOpsSchool Posted November 16, 2023 Share Posted November 16, 2023 What is Azure PowerShell? Azure PowerShell is a set of cmdlets (command-lets) for managing Azure resources from the PowerShell command line. It provides a comprehensive and powerful toolset for managing Azure resources, including virtual machines, storage accounts, databases, and networking components. Azure PowerShell is widely used by IT professionals to automate tasks, manage complex deployments, and troubleshoot Azure issues. What is cmdlets? Cmdlets, pronounced “command-lets”, are the smallest unit of functionality in PowerShell. They are lightweight commands that are used in the PowerShell environment. Each cmdlet is a .NET Framework class that packages a specific set of functionality. Cmdlets follow a verb-noun naming pattern, such as Get-Help, Get-Process, and Start-Service, which makes them self-descriptive and easy to understand. They are designed to do one thing and do it well, with a consistent interface that makes it easy to chain together in scripts for more complex tasks. Cmdlets can be used to perform operations like managing system processes, reading and writing files, and manipulating data structures. Install Azure PowerShell on Windows 1. Run the following command from PowerShell to determine your PowerShell version: $PSVersionTable.PSVersion 2. Determine if you have the AzureRM PowerShell module installed Get-Module -Name AzureRM -ListAvailable 3. Update to Windows PowerShell 5.1 4. Install .NET Framework 4.7.2 or later 5. Set the PowerShell script execution to remote signed or less restrictive. Check the PowerShell execution policy: Get-ExecutionPolicy -List 6. Set the PowerShell execution policy to remote signed: Set-ExecutionPolicy -ExecutionPolicy RemoteSigned -Scope CurrentUser 7. Copy and Paste the following command to install this package using PowerShellGet Install-Module -Name Az or Install-Module -Name Az -Repository PSGallery -Force 8. To update Update-Module -Name Az Install Azure PowerShell on Linux Open the Terminal or other shell host application and run pwsh to start PowerShell. Use the Install-Module cmdlet to install the Az PowerShell module: Install-Module -Name Az -Repository PSGallery -Force PowerShell Commands List Here are 25 basic PowerShell commands: Command nameAliasDescriptionSet-Locationcd, chdir, slSets the current working location to a specified location.Get-Contentcat, gc, typeGets the content of the item at the specified location.Add-ContentacAdds content to the specified items, such as adding words to a file.Set-ContentscWrites or replaces the content in an item with new content.Copy-Itemcopy, cp, cpiCopies an item from one location to another.Remove-Itemdel, erase, rd, ri, rm, rmdirDeletes the specified items.Move-Itemmi, move, mvMoves an item from one location to another.Set-ItemsiChanges the value of an item to the value specified in the command.New-ItemniCreates a new item.Start-JobsajbStarts a Windows PowerShell background job.Compare-Objectcompare, difCompares two sets of objects.Group-ObjectgroupGroups objects that contain the same value for specified properties.Invoke-WebRequestcurl, iwr, wgetGets content from a web page on the Internet.Measure-ObjectmeasureCalculates the numeric properties of objects, and the characters, words, and lines in string objects, such as files …Resolve-PathrvpaResolves the wildcard characters in a path, and displays the path contents.Resume-JobrujbRestarts a suspended jobSet-Variableset, svSets the value of a variable. Creates the variable if one with the requested name does not exist.Show-CommandshcmCreates Windows PowerShell commands in a graphical command window.Sort-ObjectsortSorts objects by property values.Start-ServicesasvStarts one or more stopped services.Start-Processsaps, startStarts one or more processes on the local computer.Suspend-JobsujbTemporarily stops workflow jobs.Wait-JobwjbSuppresses the command prompt until one or all of the Windows PowerShell background jobs running in the session are …Where-Object?, whereSelects objects from a collection based on their property values.Write-Outputecho, writeSends the specified objects to the next command in the pipeline. If the command is the last command in the pipeline,… Azure Powershell Commands and Cheat Sheet The post Azure PowerShell Tutorials: Installations and User Guide appeared first on DevOpsSchool.com. View the full article Quote Link to comment Share on other sites More sharing options...
