Linux Hint Posted November 10, 2023 Share Posted November 10, 2023 LangChain is the framework that is being widely used to build and configure language models across the globe. These models are a huge improvement in the NLP domain as the common people can extract to-the-point information using them. These models are trained by understanding the language and its complexities by learning the dataset multiple times called iterations. More iterations mean that the model has absorbed most of the experience or understanding of the language. Quick Outline This post will demonstrate the following: How to Configure Max Iteration Behavior With OpenAI Multi-Function Agents Installing Frameworks Importing Libraries Building Language Model Testing the Model Configuring Max Iteration Behavior Conclusion How to Configure Max Iteration Behavior With OpenAI Multi-Function Agents? With the performance of the model and its ability to understand the query, another concern is that the model should not enter the infinity loop. It means that the model should be evaluated at some point so that the performance of the model is not compromised and the resources are not wasted at the same time. To learn the process of configuring max iteration behavior with the OpenAI function in LangChain, simply follow this guide: Step 1: Installing Frameworks First of all, start the process by installing the most important framework that is LangChain using the pip command in the Python notebook: pip install langchain After installing the LangChain framework, simply install the google-search-results module of the OpenAI to get the multi-function agent: pip install openai google-search-results Now, another module to install is OpenAI which can be used to get its dependencies for building language models: pip install openai Now, simply set up the environment for the OpenAI and SerpApi by providing their API key after executing the following command: import os import getpass os.environ["OPENAI_API_KEY"] = getpass.getpass("OpenAI API Key:") os.environ["SERPAPI_API_KEY"] = getpass.getpass("Serpapi API Key:") Step 2: Importing Libraries Head into the next phase of the process by importing the required libraries for configuring the OpenAI multi-function agents: from langchain.utilities import SerpAPIWrapper from langchain.agents import initialize_agent, Tool from langchain.agents import AgentType from langchain.chat_models import ChatOpenAI Step 3: Building Language Model Build the language model using the ChatOpenAI() method with its arguments to configure the value of the model and its working. Setup the tools for using the SerpAPIWrapper() method and tools required for using the OpenAI agents: llm = ChatOpenAI(temperature=0, model="gpt-3.5-turbo-0613") search = SerpAPIWrapper() tools = [ Tool( name="Search", func=search.run, description="Ask the targeted queries about the current events to get proper responses", ), ] Configuring the agents using arguments like tools, llm, and the value of the agent which was not configured earlier and the verbose to make the output more human-friendly: mrkl = initialize_agent( tools, llm, agent=AgentType.OPENAI_MULTI_FUNCTIONS, verbose=True ) Setting the Debug flag of the LangChain True will allow backup support in case of any failure while executing the agent. As the model execution fails, it will generate the output they gathered until that point based on the provided input, and the user won’t face any error message: import langchain langchain.debug = True Step 4: Testing the Model Simply test the “mrkl” variable that was configured to invoke the agent using the input string in the argument of the run() method: mrkl.run("What is the weather in LA and SF?") The output has been displayed in the following screenshot and the max iterations were not restricted at this point: Step 5: Configuring Max Iteration Behavior Here, the code updates the “mrkl” variable by adding the max_iteration argument to set its value, and the model will only take a limited number of iterations to generate the output: mrkl = initialize_agent( tools, llm, agent=AgentType.OPENAI_FUNCTIONS, verbose=True, max_iterations=2, early_stopping_method="generate", ) Run the agent once more and the model will only take two iterations before extracting the output on the screen: mrkl.run("What is the weather in NYC today, yesterday, and the day before") Executing the above code will generate the answer containing the weather report for New York City: That’s all about configuring max iteration behavior with multi-function agents in LangChain. Conclusion To configure the max iteration behavior with OpenAI multi-function agents in LangChain, simply install the modules for configuring the agent. After that, set up the environment using the OpenAI and SerpAPi credentials to build the language model. The user can limit the max iteration behavior of the model by integrating it into the argument while initializing the agent and then running it. This guide has elaborated on the process of configuring the max iteration behavior with OpenAI multi-function agents in LangChain. View the full article Quote Link to comment Share on other sites More sharing options...
