DevOpsSchool Posted October 24, 2023 Share Posted October 24, 2023 Step 1 – Create a Project and Job with Node Steps Step 2 – Go to Webhooks under project Menu Step 3 – Create Webhook Step 4 – Add Webhook Handlers Configurations Step 5 – Validate the webhook url Step 6 – Get a User API Token Step 6 – Generate a CURL command and Run using Gitbash ENCODED_API_TOKEN=$(echo -n "6BnnOqW7EicQix9lDAn9MceNtSIQ2LBN" | base64) curl -X POST \ -H "Authorization: Basic $ENCODED_API_TOKEN" \ -H "Content-Type: application/json" \ -d '{ "webhook_id": "c6lMILXGYTvR6uaY59ZxhgsWybEfF5uF#hook1", "payload": { "key1": "value1", "key2": "value2" } }' \ http://localhost:4440/api/45/webhook/c6lMILXGYTvR6uaY59ZxhgsWybEfF5uF#hook1 The post How to Work with Rundeck Webhooks? appeared first on DevOpsSchool.com. View the full article Quote Link to comment Share on other sites More sharing options...
