Linux Hint Posted July 31, 2023 Share Posted July 31, 2023 Pop-ups refer to compact windows that emerge on your screen while browsing specific websites. They can be useful for displaying additional information, such as ads, notifications, or offers. However, some pop-ups can be annoying, intrusive, or even malicious. These pop-ups can have adverse effects, such as impeding your browsing speed, diverting your attention from desired content, or attempting to deceive you into clicking on potentially harmful elements. How To Block or Allow Pop-Ups in Chrome for Android Chrome, as the default setting, automatically prevents pop-ups from appearing on your screen. When a pop-up is blocked, the address bar will display “Pop-up blocked.” Moreover, you have the option to permit pop-ups from particular sites that you trust or consider useful. How To Allow Pop-Ups in Chrome for Android If you want to see pop-ups from websites, you can allow them in Chrome for Android and are the steps you need to follow: Step 1: Open the Chrome app on your Android phone and to the right of the address bar, tap the kebab menu icon and then tap Settings: Step 2: Tap Site settings and then tap Pop-ups and redirects: Now turn on the Pop-ups and redirects, and this setting is for all sites: How To Block Pop-Ups in Chrome for Android If you want to prevent pop-ups from interrupting your browsing experience, you can block them in Chrome for Android. Here’s how: Step 1: Open the Chrome app on your Android phone and to the right of the address bar, Kebab icon, and then tap Settings: Step 2: Tap Site Settings and then tap Pop-ups and redirects: Turn off Pop-ups and redirects by sliding the toggle to the left: How To Enable or Disable Notification Pop-Ups in Chrome on Android Further, if you want to add the prompt for displaying the notifications from any website, then go to Chrome settings and tap on Notifications: Now here tap on the toggle to either turn off or on the browser notifications, further tap on the Additional settings in app and turn on the prompt for sites before sending any notification: Conclusion Allowing pop-ups and redirects can allow you to access certain features on websites, but it can also expose you to malware and other security risks. Whereas blocking pop-ups and redirects can help protect your privacy and security, it can also prevent you from accessing certain features on websites. To allow or block popups in Chrome on Android, go to site settings and turn it on and off from there. View the full article Quote Link to comment Share on other sites More sharing options...
