Amazon Web Services Posted July 31, 2023 Share Posted July 31, 2023 In the previous post of this blog series, we saw how organizations can deploy workloads to virtual machines (VMs) in a hybrid and multicloud environment. This post shows how organizations can address the requirement of deploying containers, and containerized applications to hybrid and multicloud platforms using Amazon CodeCatalyst. CodeCatalyst is an integrated DevOps service which enables development teams to collaborate on code, and build, test, and deploy applications with continuous integration and continuous delivery (CI/CD) tools. One prominent scenario where multicloud container deployment is useful is when organizations want to leverage AWS’ broadest and deepest set of Artificial Intelligence (AI) and Machine Learning (ML) capabilities by developing and training AI/ML models in AWS using Amazon SageMaker, and deploying the model package to a Kubernetes platform on other cloud platforms, such as Azure Kubernetes Service (AKS) for inference. As shown in this workshop for operationalizing the machine learning pipeline, we can train an AI/ML model, push it to Amazon Elastic Container Registry (ECR) as an image, and later deploy the model as a container application. Scenario description The solution described in the post covers the following steps: Setup Amazon CodeCatalyst environment. Create a Dockerfile along with a manifest for the application, and a repository in Amazon ECR. Create an Azure service principal which has permissions to deploy resources to Azure Kubernetes Service (AKS), and store the credentials securely in Amazon CodeCatalyst secret. Create a CodeCatalyst workflow to build, test, and deploy the containerized application to AKS cluster using Github Actions. The architecture diagram for the scenario is shown in Figure 1. Figure 1 – Solution Architecture Solution Walkthrough This section shows how to set up the environment, and deploy a HTML application to an AKS cluster. Setup Amazon ECR and GitHub code repository Create a new Amazon ECR and a code repository. In this case we’re using GitHub as the repository but you can create a source repository in CodeCatalyst or you can choose to link an existing source repository hosted by another service if that service is supported by an installed extension. Then follow the application and Docker image creation steps outlined in Step 1 in the environment creation process in exposing Multiple Applications on Amazon EKS. Create a file named manifest.yaml as shown, and map the “image” parameter to the URL of the Amazon ECR repository created above. apiVersion: apps/v1 kind: Deployment metadata: name: multicloud-container-deployment-app labels: app: multicloud-container-deployment-app spec: selector: matchLabels: app: multicloud-container-deployment-app replicas: 2 template: metadata: labels: app: multicloud-container-deployment-app spec: nodeSelector: "beta.kubernetes.io/os": linux containers: - name: ecs-web-page-container image: <aws_account_id>.dkr.ecr.us-west-2.amazonaws.com/<my_repository> imagePullPolicy: Always ports: - containerPort: 80 resources: limits: memory: "100Mi" cpu: "200m" imagePullSecrets: - name: ecrsecret --- apiVersion: v1 kind: Service metadata: name: multicloud-container-deployment-service spec: type: LoadBalancer ports: - port: 80 targetPort: 80 selector: app: multicloud-container-deployment-app Push the files to Github code repository. The multicloud-container-app github repository should look similar to Figure 2 below Figure 2 – Files in Github repository Configure Azure Kubernetes Service (AKS) cluster to pull private images from ECR repository Pull the docker images from a private ECR repository to your AKS cluster by running the following command. This setup is required during the azure/k8s-deploy Github Actions in the CI/CD workflow. Authenticate Docker to an Amazon ECR registry with get-login-password by using aws ecr get-login-password. Run the following command in a shell where AWS CLI is configured, and is used to connect to the AKS cluster. This creates a secret called ecrsecret, which is used to pull an image from the private ECR repository. kubectl create secret docker-registry ecrsecret\ --docker-server=<aws_account_id>.dkr.ecr.us-west-2.amazonaws.com/<my_repository>\ --docker-username=AWS\ --docker-password= $(aws ecr get-login-password --region us-west-2) Provide ECR URI in the variable “–docker-server =”. CodeCatalyst setup Follow these steps to set up CodeCatalyst environment: Create a CodeCatalyst space and associated AWS account. Create a CodeCatalyst project. A CodeCatalyst environment connected to the AWS account, where the ECR repository is configured. Configure access to the AKS cluster In this solution, we use three GitHub Actions – azure/login, azure/aks-set-context and azure/k8s-deploy – to login, set the AKS cluster, and deploy the manifest file to the AKS cluster respectively. For the Github Actions to access the Azure environment, they require credentials associated with an Azure Service Principal. Service Principals in Azure are identified by the CLIENT_ID, CLIENT_SECRET, SUBSCRIPTION_ID, and TENANT_ID properties. Create the Service principal by running the following command in the azure cloud shell: az ad sp create-for-rbac \ --name "ghActionHTMLapplication" \ --scope /subscriptions/<SUBSCRIPTION_ID>/resourceGroups/<RESOURCE_GROUP> \ --role Contributor \ --sdk-auth The command generates a JSON output (shown in Figure 3), which is stored in CodeCatalyst secret called AZURE_CREDENTIALS. This credential is used by azure/login Github Actions. Figure 3 – JSON output Configure secrets inside CodeCatalyst Project Create three secrets CLUSTER_NAME (Name of AKS cluster), RESOURCE_GROUP(Name of Azure resource group) and AZURE_CREDENTIALS(described in the previous step) as described in the working with secret document. The secrets are shown in Figure 4. Figure 4 – CodeCatalyst Secrets CodeCatalyst CI/CD Workflow To create a new CodeCatalyst workflow, select CI/CD from the navigation on the left and select Workflows (1). Then, select Create workflow (2), leave the default options, and select Create (3) as shown in Figure 5. Figure 5 – Create CodeCatalyst CI/CD workflow Add “Push to Amazon ECR” Action Add the Push to Amazon ECR action, and configure the environment where you created the ECR repository as shown in Figure 6. Refer to adding an action to learn how to add CodeCatalyst action. Figure 6 – Create ‘Push to ECR’ Action Select the Configuration tab and specify the configurations as shown in Figure7. Figure 7 – Configure ‘Push to ECR’ Action Configure the Deploy action 1. Add a GitHub action for deploying to AKS as shown in Figure 8. Figure 8 – Github action to deploy to AKS 2. Configure the GitHub action from the configurations tab by adding the following snippet to the GitHub Actions YAML property: - name: Install Azure CLI run: pip install azure-cli - name: Azure login id: login uses: azure/login@v1.4.3 with: creds: ${Secrets.AZURE_CREDENTIALS} - name: Set AKS context id: set-context uses: azure/aks-set-context@v3 with: resource-group: ${Secrets.RESOURCE_GROUP} cluster-name: ${Secrets.CLUSTER_NAME} - name: Setup kubectl id: install-kubectl uses: azure/setup-kubectl@v3 - name: Deploy to AKS id: deploy-aks uses: Azure/k8s-deploy@v4 with: namespace: default manifests: manifest.yaml pull-images: true Figure 9 – Github action configuration 3. The workflow is now ready and can be validated by choosing ‘Validate’ and then saved to the repository by choosing ‘Commit’. We have implemented an automated CI/CD workflow that builds the container image of the application (refer Figure 10), pushes the image to ECR, and deploys the application to AKS cluster. This CI/CD workflow is triggered as application code is pushed to the repository. Figure 10 – Automated CI/CD workflow Test the deployment When the HTML application runs, Kubernetes exposes the application using a public facing load balancer. To find the external IP of the load balancer, connect to the AKS cluster and run the following command: kubectl get service multicloud-container-deployment-service The output of the above command should look like the image in Figure 11. Figure 11 – Output of kubectl get service Paste the External IP into a browser to see the running HTML application as shown in Figure 12. Figure 12 – Application running in AKS Cleanup If you have been following along with the workflow described in the post, you should delete the resources you deployed so you do not continue to incur charges. First, delete the Amazon ECR repository using the AWS console. Second, delete the project from CodeCatalyst by navigating to Project settings and choosing Delete project. There’s no cost associated with the CodeCatalyst project and you can continue using it. Finally, if you deployed the application on a new AKS cluster, delete the cluster from the Azure console. In case you deployed the application to an existing AKS cluster, run the following commands to delete the application resources. kubectl delete deployment multicloud-container-deployment-app kubectl delete services multicloud-container-deployment-service Conclusion In summary, this post showed how Amazon CodeCatalyst can help organizations deploy containerized workloads in a hybrid and multicloud environment. It demonstrated in detail how to set up and configure Amazon CodeCatalyst to deploy a containerized application to Azure Kubernetes Service, leveraging a CodeCatalyst workflow, and GitHub Actions. Learn more and get started with your Amazon CodeCatalyst journey! If you have any questions or feedback, leave them in the comments section. About Authors Pawan Shrivastava Pawan Shrivastava is a Partner Solution Architect at AWS in the WWPS team. He focusses on working with partners to provide technical guidance on AWS, collaborate with them to understand their technical requirements, and designing solutions to meet their specific needs. Pawan is passionate about DevOps, automation and CI CD pipelines. He enjoys watching MMA, playing cricket and working out in the gym. Brent Van Wynsberge Brent Van Wynsberge is a Solutions Architect at AWS supporting enterprise customers. He accelerates the cloud adoption journey for organizations by aligning technical objectives to business outcomes and strategic goals, and defining them where needed. Brent is an IoT enthusiast, specifically in the application of IoT in manufacturing, he is also interested in DevOps, data analytics and containers. Amandeep Bajwa Amandeep Bajwa is a Senior Solutions Architect at AWS supporting Financial Services enterprises. He helps organizations achieve their business outcomes by identifying the appropriate cloud transformation strategy based on industry trends, and organizational priorities. Some of the areas Amandeep consults on are cloud migration, cloud strategy (including hybrid & multicloud), digital transformation, data & analytics, and technology in general. Brian Beach Brian Beach has over 20 years of experience as a Developer and Architect. He is currently a Principal Solutions Architect at Amazon Web Services. He holds a Computer Engineering degree from NYU Poly and an MBA from Rutgers Business School. He is the author of “Pro PowerShell for Amazon Web Services” from Apress. He is a regular author and has spoken at numerous events. Brian lives in North Carolina with his wife and three kids. View the full article Quote Link to comment Share on other sites More sharing options...
