Linux Hint Posted July 24, 2023 Share Posted July 24, 2023 In mathematics, linear algebra deals with the study of vector spaces, matrices, linear equations, determinants, eigenvalues, and others. The “Scipy” library in Python provides a collection of tools and algorithms for scientific computing, such as the “scipy.linalg” module, which offers a rich set of functions and classes for linear algebra operations. This blog provides an in-depth tutorial on the Python “scipy.linalg” module using the below content: What is the “scipy.linalg” in Python? Solving Linear Equations Using the “scipy.linalg.solve()” Function Determining the Matrix Inverse Using the “scipy.linalg.inv()” Determining the Determinant Matrix Using the “scipy.linalg.det()” Determining the Norm of Matrices Using the “scipy.linalg.norm()” Function What is the “scipy.linalg” in Python? The “scipy.linalg” module of the Python “scipy” library contains various linear algebra functions to perform certain operations such as finding matrix determinants, determining the matrix inverse, calculating the matrices norm, etc. Both NumPy and SciPy libraries share the functionality of the “scipy.linalg” submodule. Let’s start with a “solve()” function of the “scipy.linalg” module to solve the given linear equations: Example 1: Solving Linear Equations Using the “scipy.linalg.solve()” Function This example uses the “scipy.linalg.solve()” function of the “scipy.linalg” module to solve this linear equation. 5x + 10y + 7z = 28 4x + 5y + 9z = 10 10x + 6y + 3z = 22 Here is the code: import scipy.linalg import numpy value1 = numpy.array([[5, 10, 7], [4, 5, 9], [10, 6, 3]]) value2 = numpy.array([28, 10, 22]) print(scipy.linalg.solve(value1, value2)) In the above code: The “linalg” and the “Numpy” modules are imported. The “array()” function takes the coefficient value of the right side of all the given equations as an argument and retrieves a Numpy array. The “array()” function is used again to create a Numpy array by taking the coefficient value of the right-hand side of the equation. The “linalg.solve()” function takes the input arrays representing the coefficient value of the right and left-hand side of the given linear equations and retrieves a solution array. Output The linear equation has been solved. Example 2: Determining the Matrix Inverse Using the “scipy.linalg.inv()” In this example, the “scipy.linalg.inv()” function determines the matrix inverse: import scipy.linalg import numpy value1 = numpy.array([[7, 2, 4], [4, 5, 12], [3, 4, 10]]) print(scipy.linalg.inv(value1)) In the above code: The “linalg” and “numpy” modules are imported. The “array()” function takes the equation value and initializes it as a Numpy array. The “linalg.inv()” function takes the array value as an argument and retrieves an inverse array matrix. Output The inverse of the input matrix has been determined. Example 3: Determining the Determinant Matrix Using the “scipy.linalg.det()” The “scipy.linalg.det()” function takes the matrix and retrieves the determinant (Scalar Value). Let’s overview this code: import scipy.linalg import numpy value1 = numpy.array([[7, 2, 4], [4, 5, 12], [3, 4, 10]]) print(scipy.linalg.det(value1)) In the above code, the “numpy.array()” function takes the matrix value and creates a Numpy array. The “scipy.linalg.det()” function takes the array (matrix) as an argument and retrieves the scalar value. Output The determinant of the input matrix has been determined successfully. Note: You can check this official documentation for all Python “scipy.linalg” module functions. Example 4: Determining the Norm of Matrices Using the “scipy.linalg.norm()” Function This example determines the norm or convergences of the sequence of matrices using the “scipy.linalg.norm()” function: import scipy.linalg import numpy x = numpy.array([16 , 5]) print(scipy.linalg.norm(x)) print(scipy.linalg.norm(x , 1)) In the above code: The two modules “linalg” and “numpy” are imported. The “array()” function creates a Numpy array by taking two elements as an argument. The “linalg.norm()” function takes the array as an argument and returns the norm of the matrix, which is a measure of its length or size. By default, it uses the “2-norm”, calculated as the square root of the square sum of the elements. The “linalg.norm()” function is used again to retrieve the norm of a matrix with a different value of the parameter “ord”, which specifies the type of norm to use. In this case, it uses the “1-norm”, calculated as the sum of the absolute values of the elements. Output The norm value has been calculated successfully. Conclusion The “scipy.linalg” module of the “scipy” library provides various functions such as “solve()”, “det()”, “inv()”, “norm()”, and others to perform an operation on linear algebra equations. The “scipy.linalg.solve()”, “scipy.linalg.det()”, and “scipy.linalg.inv()” functions are used to solve the linear algebraic equation, determine the determinant and inverse of the input matrix. This Python post presented a few “scipy.linalg” module functions using numerous examples. View the full article Quote Link to comment Share on other sites More sharing options...
