Linux Hint Posted July 11, 2023 Share Posted July 11, 2023 Blocking Chrome pop-ups seems like a daunting task because Pop-up ads can be troublesome while browsing the web on your Android device. Fortunately, now Google Chrome provides an effective and easy way to block these annoying pop-ups. Google Chrome provides built-in functionality to block pop-up ads. In this article, we will completely guide you through the simple steps to block pop-ups on Chrome for your Android device, allowing you to enjoy a consistent browsing experience. Why Do We Need to Block Chrome Pop-Ups on Android? There are several essential reasons to block Chrome pop-ups. Firstly, it will improve user experience. Pop-up ads can disrupt your browsing experience and interrupt your reading, scrolling, or interaction with websites. By blocking these annoying pop-up ads, you can easily browse the web without constant interruption. Secondly, it will prevent malicious content. Some pop-ups may contain malicious content, such as malware, viruses, or phishing attempts. By clicking on these pop-ups, you will lose financial security or important data. Blocking pop-ups reduces the risk of inadvertently exposing your device and personal information to such threats. Lastly, it will reduce data usage. These pop-up ads often contain multimedia elements, including images and video, which consume a lot of data when they load. By blocking these ads, you can save costs and improve browsing speed. How to Block Chrome Pop-ups on Android? You can easily block Chrome pop-ups from your Android device by following these six simple steps. Step 1: To start blocking pop-ups on Android, first open the “Google Chrome app. Step 2: Now tap the “Three-dot” menu icon which is located in the top-right corner. Step 3: From the dropdown menu, go to “Settings” to access the Browser settings. Step 4: Within the Chrome settings, scroll down and tap on “Site Settings”; this option will allow users to manage various site-related preferences, including pop-up permission. Step 5: Under the Site settings menu, locate and tap on “Pop-ups and redirects”; this will open the pop-up settings page. Step 6: To block pop-ups on Chrome, toggle the switch. Step 7: To check whether pop-ups are blocked or not, move back to Site Setting, and you will see “blocked” under the “pop-ups and redirects” option. Conclusion To enhance your browsing experience, you have to block Chrome pop-up ads from your Android device by following the above-mentioned simple steps such as opening the Google Chrome app, tapping on three dots, opening settings, then site settings, and then blocking pop-ups from pop-up and redirect options; this will control your online activities and enjoy a smoother, distraction-free browsing experience. View the full article Quote Link to comment Share on other sites More sharing options...
