Linux Hint Posted July 11, 2023 Share Posted July 11, 2023 Android devices offer a plethora of options for personalization and among all the customizable features, one is the sound notification that allows users to set a unique audio alert for different types of notifications. Changing notification sounds is essential for the personalization and differentiation of incoming notifications. Selecting a unique sound will help you to easily identify types of notifications, such as messages, emails, or social media alerts. This guide is useful in changing the notification sound on your Android device. How to Change the Notification Sound on Android? To change the notifications sound on Android devices, follow the below-given steps. Step 1: Open Settings on an Android phone and find the “Sounds & vibration” option. Its position varies depending on the Android version you are using. Step 2: Once you locate sounds or sounds & vibrations, and open it you will see an option for “Default Notification Sound”. Step 3: In the Default notification sound, you will see a list of pre-installed notification sounds. To preview these sounds, tap on any sound. Once you find the desired notification sound, select it by tapping on it. This will set it as the default notification sounds for all incoming notifications from apps. Step 4: If you want a custom notification sound, you can add your audio file to the list. Select the “Add” or “Plus” icon to browse your device’s storage and find the audio file to use as a notification sound, once you select it, it will be added to your list of sounds. Step 5: It’s important to test the selected notification sound. To test it, you can send a test notification or trigger a notification event in the respective app to ensure that the chosen sound plays correctly. Conclusion You can easily change the notifications sound on your Android device from the Settings option. To change the notification sound, you have to open Sounds & vibrations option from Settings, then choose either the default notification sound or the custom notification sound according to your preference. Ensure testing the selected notification sound to check it’s working on your Android phone. View the full article Quote Link to comment Share on other sites More sharing options...
