Amazon Web Services Posted April 7, 2023 Share Posted April 7, 2023 Amazon Relational Database Service (Amazon RDS) for MySQL now supports inbound replication from Amazon RDS Single-AZ database (DB) instances and Amazon RDS Multi-AZ DB instances with one standby to Amazon RDS Multi-AZ deployments with two readable standby database (DB) instances. You can use this inbound replication to help migrate your existing Amazon RDS MySQL deployments within minutes to Amazon RDS Multi-AZ deployments with two readable standby db instances, which has one writer instance and two readable standby instances across three availability zones. By creating a Multi-AZ deployment with two readable standby db instances as a read replica of your existing RDS MySQL database instance, you can promote the read replica to be your new primary, typically within minutes. View the full article Quote Link to comment Share on other sites More sharing options...
