Linux Hint Posted December 9, 2020 Share Posted December 9, 2020 String replacement is often essential. If you want to replace any string or word in your program, then one option is to manually check the whole program and replace each string with the desired string. Python also provides a built-in replace() function for string replacement. The Python replace() function does not replace the actual string, but it makes a copy of the string, and replaces instances of the specified string with the new string. This article shows you how to use the replace() function in Python. Syntax The syntax of the replace() function is as follows: string.replace(oldstring, newstring,count) Old String: The string that you want to replace. New String: The string that replaces the old string. Count: This parameter is optional. The count parameter is used to state the number of times you wish to replace the old string with the new string. The replace() function only returns the copy of the string. Examples We will now look at some examples of the Python replace() function. In the example given below, we will replace the term “website” with the term “linuxhint.” # declaring the original string str="Hello and welcome to the website" # replacing the "website" with "linuxhint" print("The replaced string is: ",str.replace("website","linuxhint")) Output The output is displayed in the Python console. This output shows that the term “website” has been replaced with the term “linuxhint.” Let us see another example of the replace() function. Here, we will replace the term “dog” with the term “cat.” The count value is 1, which indicates that the term “dog” will be replaced with the term “cat” only once in the string. # declaring the original string str="Dog is an animal. Dog eat food" # replacing the "Dog" with "Cat" print(str.replace("Dog","Cat",1)) Output The output is displayed in the Python console. This output shows that the first term “dog” has been replaced with the term “cat” in the string. If the count value were 2, then the function would replace the first two occurrences of the term “dog” with the term “cat” in the string. If you do not use a count value, then the replace() function replaces all instances of the specified old_string with the chosen new_string. # declaring the original string str="Dog is an animal. Dog eat food" # replacing the "Dog" with "Cat" print(str.replace("Dog","Cat",2)) Output The output is displayed in the Python console. This output shows that the two occurrences of the term “dog” have been replaced with the term “cat” in the string. As discussed earlier, the replace() function only returns a copy of the original string. It does not change the original string. We will now print the original string after replacing the term “dog” with the term “cat.” # declaring the original string str="Dog is an animal. Dog eat food" # replacing the "Dog" with "Cat" print("Replaced string: ",str.replace("Dog","Cat",2)) # printing the original string print("Original String: ",str) Output The output is displayed in the Python console. This output shows that the original string remained the same. The replace() function only returns the copy of the original string after making the changes. Conclusion This article explains string replacement in Python using the replace() function with the help of some simple examples. The article should have helped beginners to learn more about performing string replacement in Python using the replace() function. View the full article Quote Link to comment Share on other sites More sharing options...
