DevOpsCube Posted December 8, 2022 Share Posted December 8, 2022 In this blog, I will discuss why you need python for DevOps and its real-world use cases. Also, I have added the resources and roadmap to learn python for a DevOps engineer. Programming is becoming an essential skill for DevOps engineers. It doesn’t mean DevOps engineers have to develop full-fledged applications like developers. The development use case is different for DevOps engineers. In my DevOps engineers guide, I have written about the importance of programming & Scripting for Devops engineers. Python For DevOps When it comes to DevOps, Python is the preferred programming language for automation. The latest Python Developers Survey conducted by JetBrains shows that 38% of python usage is reported for DevOps, Automation, and System Administration. Now let’s look at Python’s different use cases for DevOps. 1. CI/CD, Infrastructure provisioning & Configuration Management Many open-source tools are available for infrastructure provisioning, configuration management, continuous integration, continuous deployment, etc. However, there are scenarios where the native tooling functionality might not be sufficient to implement the required functionality. Here is where languages like Python come in to picture. For example, Making an API call to get a secret token while deploying. Reading a CSV file to get specific data during application deployments. In Ansible, you can create custom modules using Python when no module is available for the implementation you are looking for. 2. DevOps Platform Tooling In most organizations, as part of platform engineering efforts, central DevOps platform teams develop the in-house platform and tooling for internal teams. While developing these platforms, DevOps engineers need to work with programming languages and scripting languages to build utilities and scripts for platform automation requirements. 3. Cloud Automation Boto3 is an excellent example of Python usage for Cloud Automation. It is an extensively used python module for AWS cloud-related automation and scripts. As a DevOps engineer, you might also have to develop lambda functions in Python for infrastructure-related tasks. 4. Monitoring & Alerting Even though every organization has monitoring tools, there are use cases where you need a customized solution for monitoring and alerting. You can use the relevant python SDKs or custom modules to implement the solution in such cases. For example, a custom autoscaler based on alerts where a webhook listens to incoming alerts to take scaling decisions. You can automate the whole autoscaling process using a simple Python Flask application. 5. MLOPS Another area where Python is extensively used is MLOPS (Machine Learning Operations). When DevOps engineers work with ML application development teams, most workflows require Python. For example, Airflow tool is a standard ML & data engineering pipeline tool. In most cases, DevOps engineers are responsible for creating these pipelines in collaboration with ML and Data engineers. However, there are complex use cases where the involvement of data engineers is required. Python Learning Roadmap For DevOps Engineers If you are starting your DevOps engineer journey and want to learn python, the question your might have is, how much python is required for DevOps? Here is a Python learning roadmap for DevOps Engineers with the relevant resources. Python environment setup Basic syntax Variables Python Data Types Conditionals Loops Regular expressions. Methods Modules Exception handling Utilizing Python cloud SDKs (Boto3) Once you learn the above concepts, you can start with hands-on python scripting on the real-world use cases listed in the next section. If you are looking for a guided way to learn Python from scratch., I recommend the following free python resources. Learn Python 3 from Scratch Introduction to Python Programming Python for Beginners – Full Course Important Python Modules for DevOps Automation There are a lot of python modules for various use cases. However, when it comes to DevOps, there are python devops libraries that you will have to use repeatedly for automation tasks. Here is the list. os module platform subprocess sys psutil re (Regular Expression) scapy Requests and urllib3 logging getpass boto3 paramiko JSON PyYAML pandas: One of the best data science frameworks. However, it is very useful for DevOps automation tasks dealing with CSV files. smtplib Real World Python Automation Use Cases For DevOps Now let’s take a look at some of the real-world use cases of Python scripting in DevOps. I have added the use cases under different categories. Generic Python DevOps Use Cases Python Script to query databases Python script to execute a shell script and shell commands. Querying Splunk logs for specific alerting Python script to create Kafka Topics Python script to take backups. Python script for Kubernetes init containers code to fetch secrets from the vault. Python script to fetch IPs of live servers in an autoscaling group. Python AWS Lambda function to stop running instances on weekends. Python script for ETL jobs. Find SSL expiry date using python Develop custom CLI applications using Python CRUD operations using Python for databases. Custom scripts while using configuration management tools. Cloud-Specific Python Use Cases When working on cloud environments, you might need custom automation scripts as part of Infrastructure as code implementations. Let’s take a look at some real-world cloud-specific python use cases. Provision AWS resources using python AWS CDK. Use Boto3 modules to manage AWS services. Python Boto3 program to manage AWS ec2 instances. Python Boto3 program to manage AWS S3 Storage. Python For DevOps GitHub Repo I have created a GitHub repository where DevOps-related python scripts and programs will be added for learning and implementation. The repo primarily focuses on generic python scripts, boto3, OS-related python scripts, and more. It is an open-source repo that will accept community contributions. Repo: Python for DevOps Scripts Or you can clone the repo. git clone https://github.com/techiescamp/python-for-devops How Important is Python for DevOps Engineers? Coding for DevOps engineers is a highly debated topic. However, In my experience as a DevOps engineer, I encountered many situations where I had to use Python for DevOps in terms of automation, continuous integration/deployment/delivery (CI/CD), and custom auto-scaling solutions. Also, When it comes to DevOps engineer interviews, Python plays a key role. Most Devops preliminary interview rounds have live coding sessions. Therefore, you will have to solve programming challenges related to devops. With a good knowledge of Python, you can easily crack these interviews. I have searched a job portal for Devops openings, and more than 7941 jobs mentioned Python as a requirement in all experience levels. Python Automation Case Studies If you want to know how python is real-world project implementations, you should look at case studies published by organizations. Following are some of the case studies that will help you gain more insights into automation using python. How NetFlix uses python How Facebook Engineering uses Python Python For DevOps FAQs Is Python useful for DevOps? Python is one of the best programming languages for Automation in DevOps. DevOps teams use Python for automating repetitive tasks, infrastructure provisioning, and API-driven deployments. CI/CD workflows and much more. Should I learn Go or Python for DevOps? Golang & Python have widely used programming languages in DevOps. Choosing a language depends on the use case. Python is easy to get started and has strong support for automation, and system administration tasks, and can be used to build complex workflows and pipelines along with existing devops tools. Golang offers better performance and more advanced features for distributed systems. Tools like Kubernetes, and Terraform are built with Golang and you can extend these tools using Golang. Conclusion Programming and scripting knowledge is becoming essential for DevOps Engineers. And one of the best programming languages for DevOps is also python. Also, When it comes to DevOps tools, you will end up using a programming or scripting language to achieve custom implementations. Even if you are not actively working on scripting in your day-to-day devops engineer job, I would highly suggest you learn python and create open-source utilities and scripts. It will definitely help you in a long run. View the full article Quote Link to comment Share on other sites More sharing options...
