DevOpsCube Posted December 13, 2022 Share Posted December 13, 2022 In this article, we will go through a step-by-step guide on how to create Helm chart and discuss its structure components and best practices. If you want to learn helm chart basics and get hands-on with helm charts, you will love this guide. Prerequisites To get started with helm charts, you need to have the following. A working Kubernetes cluster Helm installed on your workstation A valid kubeconfig to connect to the cluster Working knowledge of Kubernetes and YAML. What is Helm Chart? For the purpose of explanation, I am choosing a very basic example of a website frontend deployment using Nginx on Kubernetes Let’s assume you have four different environments in your project. Dev, QA, Staging, and Prod. Each environment will have different parameters for Nginx deployment. For example, In Dev and QA you might need only one replica. In staging and production, you will have more replicas with pod autoscaling. The ingress routing rules will be different in each environment. The config and secrets will be different for each environment. Because of the change in configs and deployment parameters for each environment, you need to maintain different Nginx deployment files for each environment. Or you will have a single deployment file and you will need to write custom shell or python scripts to replace values based on the environment. But it is not a scalable approach. Here is where the helm chart comes in to picture. Helm charts are a combination of Kubernetes YAML manifest templates and helm-specific files. You can call it a helm package. Since the Kubernetes YAML manifest can be templated, you don’t have to maintain multiple helm charts of different environments. Helm uses the go templating engine for the templating functionality. You just need to have a single helm chart and you can modify the deployment parameters of each environment by just changing a single values file. Helm will take care of applying the values to the templates. We will learn more about it practically in the next sections. At a high level, Helm Charts reduce the complexity and duplicacy of each environment (dev, uat, cug, prod) with only one template. Helm Chart Structure To understand the Helm chart, let’s take an example of Nginx deployment. To deploy Nginx on Kubernetes, typically you would have the following YAML files. nginx-deployment ├── configmap.yaml ├── deployment.yaml ├── ingress.yaml └── service.yaml Now if we create a Helm Chart for the above Nginx deployment, it will have the following directory structure. nginx-chart/ |-- Chart.yaml |-- charts |-- templates | |-- NOTES.txt | |-- _helpers.tpl | |-- deployment.yaml | |-- configmap.yaml | |-- ingress.yaml | |-- service.yaml | `-- tests | `-- test-connection.yaml `-- values.yaml As you can see, the deployment YAML files are part of the template directory (highlighted in bold) and there are helm-specific files and folders. Let’s look at each file and directory inside a helm chart and understand its importance. .helmignore: It is used to define all the files which we don’t want to include in the helm chart. It works similarly to the .gitignore file. Chart.yaml: It contains information about the helm chart like version, name, description, etc. values.yaml: In this file, we define the values for the YAML templates. For example, image name, replica count, HPA values, etc. As we explained earlier only the values.yaml file changes in each environment. Also, you can override these values dynamically or at the time of installing the chart using --values or --set command. charts: We can add another chart’s structure inside this directory if our main charts have some dependency on others. By default this directory is empty. templates: This directory contains all the Kubernetes manifest files that form an application. These manifest files can be templated to access values from values.yaml file. Helm creates some default templates for Kubernetes objects like deployment.yaml, service.yaml etc, which we can use directly, modify, or override with our files. templates/NOTES.txt: This is a plaintext file that gets printed out after the chart is successfully deployed. templates/_helpers.tpl: That file contains several methods, and sub-template. These files are not rendered to Kubernetes object definitions but are available everywhere within other chart templates for use. templates/tests/: We can define tests in our charts to validate that your chart works as expected when it is installed. Helm Chart Tutorial GitHub Repo The example helm chart and manifests used in this guide are hosted on the Helm Chart Github repo. You can clone it and use it to follow along with the guide. git clone https://github.com/techiescamp/helm-tutorial.git Create Helm Chart From Scratch To get hands-on with helm chart creation, let’s create an Nginx helm chart from scratch. Execute the following command to create the chart boilerplate. It creates a chart with the name nginx-chart with default files and folders. helm create nginx-chart If you check the created chart, it will have the following files and directories. nginx-chart │ ├── Chart.yaml │ ├── charts │ ├── templates │ │ ├── NOTES.txt │ │ ├── _helpers.tpl │ │ ├── deployment.yaml │ │ ├── hpa.yaml │ │ ├── ingress.yaml │ │ ├── service.yaml │ │ ├── serviceaccount.yaml │ │ └── tests │ │ └── test-connection.yaml │ └── values.yaml Let’s cd into the generated chart directory. cd nginx-chart We’ll edit the files one by one according to our deployment requirements. Chart.yaml As mentioned above, we put the details of our chart in Chart.yaml file. Replace the default contents of chart.yaml with the following. apiVersion: v2 name: nginx-chart description: My First Helm Chart type: application version: 0.1.0 appVersion: "1.0.0" maintainers: - email: contact@devopscube.com name: devopscube apiVersion: This denotes the chart API version. v2 is for Helm 3 and v1 is for previous versions. name: Denotes the name of the chart. description: Denotes the description of the helm chart. Type: The chart type can be either ‘application’ or ‘library’. Application charts are what you deploy on Kubernetes. Library charts are re-usable charts that can be used with other charts. A similar concept of libraries in programming. Version: This denotes the chart version. appVersion: This denotes the version number of our application (Nginx). maintainers: Information about the owner of the chart. We should increment the version and appVersion each time we make changes to the application. There are some other fields also like dependencies, icons, etc. templates There are multiple files in templates directory created by helm. In our case, we will work on simple Kubernetes Nginx deployment. Let’s remove all default files from the template directory. rm -rf templates/* We will add our Nginx YAML files and change them to the template for better understanding. Create a deployment.yaml file and copy the following contents. apiVersion: apps/v1 kind: Deployment metadata: name: nginx-deployment labels: app: nginx spec: replicas: 2 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - name: nginx image: "nginx:1.16.0" imagePullPolicy: IfNotPresent ports: - name: http containerPort: 80 protocol: TCP If you see the above YAML file, the values are static. The idea of a helm chart is to template the YAML files so that we can reuse them in multiple environments by dynamically assigning values to them. To template a value, all you need to do is add the object parameter inside curly braces as shown below. It is called a template directive and the syntax is specific to the Go templating {{ .Object.Parameter }} First Let’s understand what is an Object. Following are the three Objects we are going to use in this example. Release: Every helm chart will be deployed with a release name. If you want to use the release name or access release-related dynamic values inside the template, you can use the release object. Chart: If you want to use any values you mentioned in the chart.yaml, you can use the chart object. Values: All parameters inside values.yaml file can be accessed using the Values object. To know more about supported Objects check the Helm Builtin Object document. The following image shows how the built-in objects are getting substituted inside a template. First, you need to figure out what values could change or what you want to templatize. I am choosing name, replicas, container name, image and imagePullPolicy which I have highlighter in the YAML file in bold. name: name: {{ .Release.Name }}-nginx : We need to change the deployment name every time as Helm does not allow us to install releases with the same name. So we will templatize the name of the deployment with the release name and interpolate -nginx along with it. Now if we create a release using the name frontend, the deployment name will be frontend-nginx. This way, we will have guaranteed unique names. container name: {{ .Chart.Name }}: For the container name, we will use the Chart object and use the chart name from the chart.yaml as the container name. Replicas: {{ .Values.replicaCount }} We will access the replica value from the values.yaml file. image: "{{ .Values.image.repository }}:{{ .Values.image.tag }}" Here we are using multiple template directives in a single line and accessing the repository and tag information under the image key from the Values file. Similarly, you can templatize the required values in the YAML file. Here is our final deployment.yaml file after applying the templates. The templated part is highlighted in bold. Replace the deployment file contents with the following. apiVersion: apps/v1 kind: Deployment metadata: name: {{ .Release.Name }}-nginx labels: app: nginx spec: replicas: {{ .Values.replicaCount }} selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - name: {{ .Chart.Name }} image: "{{ .Values.image.repository }}:{{ .Values.image.tag }}" imagePullPolicy: {{ .Values.image.pullPolicy }} ports: - name: http containerPort: 80 protocol: TCP Create service.yaml file and copy the following contents. apiVersion: v1 kind: Service metadata: name: {{ .Release.Name }}-service spec: selector: app.kubernetes.io/instance: {{ .Release.Name }} type: {{ .Values.service.type }} ports: - protocol: {{ .Values.service.protocol | default "TCP" }} port: {{ .Values.service.port }} targetPort: {{ .Values.service.targetPort }} In the protocol template directive, you can see a pipe ( | ) . It is used to define the default value of the protocol as TCP. So that means we won’t define the protocol value in values.yaml file or if it is empty, it will take TCP as a value for protocol. Create a configmap.yaml and add the following contents to it. Here we are replacing the default Nginx index.html page with a custom HTML page. Also, we added a template directive to replace the environment name in HTML. apiVersion: v1 kind: ConfigMap metadata: name: {{ .Release.Name }}-index-html-configmap namespace: default data: index.html: | <html> <h1>Welcome</h1> </br> <h1>Hi! I got deployed in {{ .Values.env.name }} Environment using Helm Chart </h1> </html values.yaml The values.yaml file contains all the values that need to be substituted in the template directives we used in the templates. For example, deployment.yaml template contains template directive to get the image repository, tag, and pullPolicy from the values.yaml file. If you check the following values.yaml file, we have repository, tag, and pullPolicy key-value pairs nested under the image key. That is the reason we used Values.image.repository Now, replace the default values.yaml content with the following. replicaCount: 2 image: repository: nginx tag: "1.16.0" pullPolicy: IfNotPresent service: name: nginx-service type: ClusterIP port: 80 targetPort: 9000 env: name: dev Now we have the Nginx helm chart ready and the final helm chart structure looks like the following. nginx-chart ├── Chart.yaml ├── charts ├── templates │ ├── configmap.yaml │ ├── deployment.yaml │ └── service.yaml └── values.yaml Validate the Helm Chart Now to make sure that our chart is valid and, all the indentations are fine, we can run the below command. Ensure you are inside the chart directory. helm lint . If you are executing it from outside the nginx-chart directory, provide the full path of nginx-chart helm lint /path/to/nginx-chart If there will be no error or issue, it will show this result ==> Linting ./nginx [INFO] Chart.yaml: icon is recommended 1 chart(s) linted, 0 chart(s) failed To validate if the values are getting substituted in the templates, you can render the templated YAML files with the values using the following command. It will generate and display all the manifest files with the substituted values. helm template . We can also use --dry-run command to check. This will pretend to install the chart to the cluster and if there will be some issue it will show the error. helm install --dry-run my-release nginx-chart If everything is good, then you will see the manifest output that would get deployed into the cluster. Deploy the Helm Chart When you deploy the chart, Helm will read the chart and configuration values from the values.yaml file and generates the manifest files. Then it will send these files to the Kubernetes API server, and Kubernetes will create the requested resources in the cluster. Now we are ready to install the chart. Execute the following command where nginx-release is release name and nginx-chart is the chart name. It installs nginx-chart in the default namespace helm install frontend nginx-chart You will see the output as shown below. NAME: frontend LAST DEPLOYED: Tue Dec 13 10:15:56 2022 NAMESPACE: default STATUS: deployed REVISION: 1 TEST SUITE: None Now you can check the release list using this command: helm list Run the kubectl commands to check the deployment, services, and pods. kubectl get deployment kubectl get services kubectl get configmap kubectl get pods We can see the deployment frontend-nginx, nginx-service and pods are up and running as shown below. We discussed how a single helm chart can be used for multiple environments using different values.yaml files. To install a helm chart with external values.yaml file, you can use the following command with the --values flag and path of the values file. helm install frontend nginx-chart --values env/prod-values.yaml When you have Helm as part of your CI/CD pipeline, you can write custom logic to pass the required values file depending on the environment. Helm Upgrade & Rollback Now suppose you want to modify the chart and install the updated version, we can use the below command: helm upgrade frontend nginx-chart For example, we have changed the replicas from 2 to 1. You can see the revision number is 2 and only 1 pod is running. Now if we want to roll back the changes which we have just done and deploy the previous one again, we can use the rollback command to do that. helm rollback frontend The above command will roll back the helm release to the previous one. After the rollback, we can see 2 pods are running again. Note that helm takes the rollback as a new revision, that’s why we’re getting the revision as 3. If we want to roll back to the specific version we can put the revision number like this. helm rollback <release-name> <revision-number> For example, helm rollback frontend 2 Uninstall The Helm Release To uninstall the helm release use uninstall command. It will remove all of the resources associated with the last release of the chart. helm uninstall frontend We can package the chart and deploy it to Github, S3, or any other platform. helm package frontend Debugging Helm Charts We can use the following commands to debug the helm charts and templates. helm lint: This command takes a path to a chart and runs a series of tests to verify that the chart is well-formed. helm get values: This command will output the release values installed to the cluster. helm install --dry-run: Using this function we can check all the resource manifests and ensure that all the templated are working fine. helm get manifest: This command will output the manifests that are running in the cluster. helm diff: It will output the differences between the two revisions. helm diff revision nginx-chart 1 2 Helm Chart Possible Errors If you try to install an existing helm package, you will get the following error. Error: INSTALLATION FAILED: cannot re-use a name that is still in use To update or upgrade the release, you need to run the upgrade command. If you try to install a chart from a different location without giving the absolute path of the chart you will get the following error. Error: non-absolute URLs should be in form of repo_name/path_to_chart To rectify this, you should execute the helm command from the directory where you have the chart or provide the absolute path or relative path of the chart directory. Helm Charts Best Practices Following are some of the best practices to be followed when developing a helm chart. Document your chart by adding comments and a README file as documentation is essential for ensuring maintainable Helm charts. We should name the Kubernetes manifest files after the Kind of object i.e deployment, service, secret, ingress, etc. Put the chart name in lowercase only and if it has more than a word then separate out with hyphens (-) In values.yaml file field name should be in lowercase. Always wrap the string values between quote signs. Use Helm version 3 for simpler and more secure releases. Check this document for more details Conclusion To summarize, We discussed the Helm Chart and its structure in detail. We created a helm chart from scratch and deployed it. Also learned how to upgrade, roll back, and uninstall it. Helm is a very useful package manager for Kubernetes. When you have different environments with custom deployment requirements, helm provides a great way to templatize kubernetes manifests as per our needs. Helm-specific functionalities like chart dependencies and chart reusability make it one of the good kubernetes tools. Also, if you check our learning kubernetes guide, we have mentioned helm as must learn tool for Kubernetes package management. View the full article Quote Link to comment Share on other sites More sharing options...
