Devops.com Posted November 16, 2022 Share Posted November 16, 2022 Seriously. The more you can shift things like security and test to the left, the more responsive the DevOps process will be. Some things are better shifted right … But only while solving the problem with shifted-left work. A good example is blocking zero-day attacks proactively while the development process fixes the code to stop […] The post Shift That [bleep] Left appeared first on DevOps.com. View the full article Quote Link to comment Share on other sites More sharing options...
