Amazon Web Services Posted October 18, 2022 Share Posted October 18, 2022 Today, AWS launched the AWS Parameters and Secrets Lambda Extension, a convenient method for AWS Lambda users to retrieve parameters from AWS Systems Manager Parameter Store and secrets from AWS Secrets Manager. AWS Lambda customers can leverage this extension to improve their application performance as it decreases the latency and the cost of retrieving parameters and secrets. Previously, customers had to initialize either the core library of a service or the entire service SDK inside a Lambda function for retrieving secrets and parameters, now they can simply use the extension. This lightweight and easy-to-use extension caches parameters and secrets, and persists them throughout the lifecycle of the Lambda function. The extension runs inside an isolated execution environment using the same permissions as the role of the user running the Lambda function. View the full article Quote Link to comment Share on other sites More sharing options...
