Amazon Web Services Posted September 27, 2022 Share Posted September 27, 2022 Starting today, you can create budgets using a simplified 1-click workflow for common budgeting scenarios as well as take step-by-step tutorials to learn about creating different kinds of budgets. AWS Budgets helps you track against expected spend by sending alerts when your cost and usage exceeds (or is forecasted to exceed) thresholds you define, or when your Reserved Instances and Savings Plans' utilization and/or coverage rate drops below a threshold. 1-click templates and tutorials are intended for new and existing users seeking guidance on what budgets they can set to control costs in AWS. View the full article Quote Link to comment Share on other sites More sharing options...
