Things to consider when running visual tests in CI/CD pipelines: Container Pipeline Edition (Part 3)
Microsoft
 Share
If you’ve used Jenkins for awhile now, you might know you can run Jenkins within your Kubernetes cluster and take advantage of the Docker socket to run container based pipelines.
What is a container based pipeline? In short, it’s a pipeline where each task runs in a container. The benefit of this is I don’t need to spend time configuring my build server or build environment with all the necessary dependencies and binaries needed for my pipeline...
The post Things to consider when running visual tests in CI/CD pipelines: Container Pipeline Edition (Part 3) appeared first on Azure DevOps Blog.
Link to comment
Share on other sites
  Only 75 emoji are allowed.
 Share
  • Create New...
