Amazon Web Services Posted August 11, 2022 Share Posted August 11, 2022 AWS has further enhanced the monitoring set up experience through Amazon CloudWatch Application Insights' integration with AWS Service Catalog AppRegistry. With this feature, you can now easily select a registered AWS application or register a new one with AppRegistry directly from Application Insights and automatically set up monitoring for the newly registered applications. Registered applications are available for other services that make use of registered applications so you can seamlessly interact with your applications in these AWS services as well. View the full article Quote Link to comment Share on other sites More sharing options...
