Fine-tuning blue/green deployments on application load balancer
AWS
 Share
In a traditional approach to application deployment, you typically fix a failed deployment by redeploying an older, stable version of the application. Redeployment in traditional data centers is typically done on the same set of resources due to the cost and effort of provisioning additional resources. Applying the principles of agility, scalability, and automation capabilities of AWS can shift the paradigm of application deployment. This enables a better deployment technique called blue/green deployment...
Link to comment
Share on other sites
  Only 75 emoji are allowed.
 Share
  • Create New...
