Linux Hint Posted June 2, 2021 Share Posted June 2, 2021 A PSU plays a significant role in determining how reliable your system’s performance is. Therefore, you should be extra careful when choosing a suitable power supply for your system. The best power supply should also have additional features to keep your expensive pc components secure in case of a sudden power outage. If not, it’s not the right PSU for your system. Of course, power supply selection also depends on your needs, whether you are running a basic gaming desktop, an overclocking monstrous mining rig, or an always-on workstation. To make your research easier, we have come up with a small list of the available best PSUs for gaming. But you can also use them for productivity workstations. Take a look and see if you find something worthy of your attention. 1. Corsair RMX Series CP-9020179-NA The Corsair RMX Series CP-9020179-NA Power Supply is budget-friendly and the most popular option to power up your hardcore gaming system. It is a highly reliable and long-lasting power supply, backed by a 10-year warranty. It offers different models ranging from 550 watts to 1000 watts for everyone’s unique needs. You can conveniently pair it up with any gaming system. The PSU is capable of handling overclocking with high-end components and delivers top-notch efficacy. It features Japanese-made high-end capacitors that can handle additional power load without breaking down and are 80 plus Gold Certified. The Corsair RMX CP-9020179 PSU also has a zero-meter RPM fan mode that operates silently when not under heavy load. This power supply comes with more than enough fully modular PCI-E cables. Built to last and high quality, these cables bring the overall cost of the package down. However, if you have multiple graphics cards running in parallel, there may not be enough juice to sustain the system. Other than that, if you’re a gamer looking for a reliable yet economical PSU, the Corsair RMX series has your guy. Buy Here: Amazon 2. EVGA SuperNOVA 220-G2-0650-Y1 Over time, we have used EVGA SuperNOVA 220-G2-0650-Y1 Fully Modular Power Supply in various systems, and it continues to impress with performance. It conveniently fits different molds from medium to larger builds. Not to mention, it is available in various capacities, going as low as 550watts and as high as 1600watts. As far as the quality is concerned, it features Japanese capacitors for long-lasting operation, a complete modular system for cable management, and is backed by a 10-year warranty. Its overall construction style is also pretty impressive; all the cables have been braided nicely, while the surface finish looks extremely elegant. There are two modes for the fan that you can use, ECO mode and regular mode. On ECO mode, the fan only runs when needed to enhance its lifespan, while the regular mode keeps the fan running without any noticeable noise. While there is a slight hum of the fan, it’s not distracting. It also has an efficient cable management system. So, there will not be a mess of wires lying around your desktop. On the whole, SuperNOVA 220-G20-0650-Y1 is a mighty PSU that will go well, particularly with GTX-1080, GTX-1070, GTX1080i. You can even pair it up with a multi-GPU computer to deliver maximum power efficiency. Buy Here: Amazon 3. Seasonic PRIME TX-1000 Our third recommendation for the best power supply for gaming computers, here is Seasonic PRIME TX-1000. The manufacturer has done its best to offer sky-high efficiency to its user, but it does come at a higher price point. The PSU has incredible soldering work and features Japanese capacitors with the top-notch build quality. It also uses polymer caps with electrolyte caps along with a fluid dynamic bearing fan that doesn’t make any noise. Plus, we are also head over heels about the high rail efficiency this PSU offers us at 5VS. As for the performance, the Seasonic PRIME TX-1000 Modular Power Supply holds up its end of the bargain well. It successfully achieves tight load regulations on all rails along with having a magnificent ripple suppression. It doesn’t use the in-line caps and is capable of holding up time accurately. Another benefit of buying Seasonic PRIME TX-1000 Modular Power Supply is that it features six dedicated PCIe connectors for different cables, so you will not face any trouble powering up your graphics card. Buy Here: Amazon 4. Cooler Master V850 SFX Gold Many people believe that they might have to settle for a less powerful system just because they prefer a built-in mini ITX case. However, it’s not true especially if you opt for the Cooler Master V850 SFX Gold Full Modular PSU. It’s a powerful PSU that comes in a small SFX box. Thus, it gives you all the juice you need to power your system up. At the same time, fitting effortlessly into your mini builds. Moreover, the V850 is a full module power supply, so you can conveniently swap any of the available cables. Though Cooler Master has included all the cables that you are possibly going to need in the package, if you have a different style in mind, or you prefer different lengths of wires, you can always get those separately. Last but not least, this power supply delivers 80 plus gold power efficiency and features a highly dynamic fluid bearing fan for a noise-free operation. Buy Here: Amazon 5. Fractal Design Ion SFX 650G Many brands have taken over the small form factor category when coming with the latest PSUs. This category has garnered interest from gamers as well, which is why the Fractal Design Ion SFX 650G Full Modular PSU is an interesting option. This power supply doesn’t fall into the accurate SFX dimensions and is instead known as SFX-L. It features a larger depth than SFX power supplies but features high-quality cooling fans with better airflow. What’s more, the Ion SFX 650G can handle the heavier load without breaking a sweat. The fully modular design ensures you only use the cables that you need. Plus, the flex on them is great enough to tuck the wires away. This makes it an excellent option for tiny spaces. The main advantage of choosing this PSU is that it offers a better cooling system and much more flexible modular cables that will make the cable routing and installation process more manageable. Lastly, you will also find an SFA-to-ATX adapter in the package if you want to use the PSU with an ATX chassis. Buy Here: Amazon Buyer’s Guide for the Best Computer Power Supply Finding the best power supply isn’t as difficult of a task if you know what you’re looking for. Trust us, if you keep these points in perspective, you will never regret your purchase. Capacity Before you opt for a PSU, you need to figure out how much power you need to run your system. You need to understand that most computer components draw power from the PSU. So, if you have planned to add more components in the future, you will need a PSU to support the additional power draw. We suggest calculating the wattage of all of the computer components that will be drawing from the source. It mainly depends on your CPU and your GPU or GPUs. Once you have a figure for each component, add them together, and you will have a combined wattage. So, whatever figure you get, make sure the power supply you purchase has a higher wattage in comparison. Efficiency How do you determine whether a PSU is efficient or not? It’s simple. A power supply converts the AC power into DC power. During this conversion, some of the power is lost as heat wastage. You need to find a power supply that converts at least 80 or 90% of the AC power to DC. You must have noticed above that all the models we recommended came with 80 plus certified ratings. That means they can convert more than 80% of the AC power to DC without producing a lot of heat wastage. Single Rail or Multi-Rail A single rail PSU has a single +12 Volts rail that feeds power to system components. Therefore, all of its power is available to any component in the system, regardless of the cable. On the other hand, a multi-rail divides its wattage between two or more +12 Volts rails. It cannot share power among different rails. From a performance point of view, both work great and are safe to use. However, if you want to build a powerful rig, a multi-rail PSU will provide an additional layer of protection in case of a short circuit. Components Having a PSU made out of high-quality components will produce an ample amount of energy. It will also have a better overall lifespan. Whereas, a cheaply constructed PSU won’t last long and also wouldn’t work well under heavier loads. Make sure the model you are buying is built out of high-quality components and can withstand added pressure. Final Thoughts So, this is everything we could gather on the best power supply for gaming computers. From the GPU to your CPU, everything in your system will only work as well as your PSU is. This is why you need to pay extra attention and money when buying a suitable power supply. We hope the article has been informative enough to help you make the most of your purchase. Thank you for reading. View the full article Quote Link to comment Share on other sites More sharing options...
