Posted March 11Mar 11 Amazon Bedrock Flows and Amazon Bedrock Prompt Management are now available in AWS GovCloud (US) and Europe (Stockholm) regions. Flows helps you accelerate the creation, testing, and deployment of predefined generative AI workflows. You can use the visual builder or SDK to connect the latest foundation models, prompts, agents, knowledge bases, and other AWS services to create and test generative AI workflows. You can easily experiment with Flows using the visual builder or APIs, A/B test multiple flow versions, and deploy and scale to production using serverless infrastructure. Prompt Management helps you simplify the creation, evaluation, versioning, and sharing of prompts to get the best responses from foundation models for your use cases. You can use the Prompt Builder to experiment with multiple foundation models, model configurations, and prompt messages. You can test and compare prompts in-place using the Prompt Builder without deployment. To share prompts for use in downstream applications, you can create a version and make an API call to retrieve the prompt. Both Bedrock Flows and Prompt Management are now available in AWS GovCloud (US) and Europe (Stockholm) regions, in addition to existing commercial regions. To get started, see the following resources: Blog post Amazon Bedrock user guide for Flows Amazon Bedrock user guide for Prompt Management View the full article
