AWS makes it easier for developers to build serverless applications by bringing Serverless Land's extensive application pattern library directly into the Visual Studio Code (VS Code) IDE. This integration eliminates the need to switch between your development environment and external resources when building serverless architectures by enabling you to browse, search, and implement pre-built serverless patterns directly in VS Code IDE. This new feature simplifies and accelerates the process of building serverless applications using VS Code IDE.
Serverless Land provides hundreds of curated serverless application patterns covering popular use cases across AWS services like AWS Lambda, Amazon Simple Queue Service (SQS), Amazon API Gateway, AWS Step Functions, Amazon EventBridge, and many more. With Serverless Land integration in VS Code IDE, you can now use familiar VS Code interface to search and filter application patterns based on AWS services, Infrastructure as Code (IaC) frameworks, and language runtime requirements. When you find a pattern that matches your use case, you can preview the implementation details and download the pattern code directly to your workspace using the Quick Pick functionality of VS Code. This integration ensures that you now have easy access to reliable serverless application patterns which are regularly updated and align with AWS best practices, enhancing your serverless development experience.
The Serverless Land patterns are now available to all developers with the AWS Toolkit (v3.48.0 or later) installed on their VS Code IDE. To learn more about this experience and how to get started, visit the AWS Toolkit developer guide. To learn more about Serverless Land patterns, visit ServerlessLand.com.
