Amazon Cognito now allows customers to customize access tokens for M2M flows, enabling you to implement fine-grained authorization in your applications, APIs, and workloads. M2M authorization is commonly used for automated processes such as scheduled data synchronization tasks, event-driven workflows, microservices communication, or real-time data streaming between systems. In M2M authorization flows, an app client can represent a software system or service that can request access tokens to interact with resources, such as a reporting system or a data processing service. With this launch, customers can now customize their access tokens with custom claims (attributes about the app client) and scopes (level of access that an app client can request to a resource), making it easier to control and manage how their automated systems interact with each other.
Customers can now add custom attributes directly in access tokens, reducing the complexity of authorization logic needed in their application code. For example, customers can customize access tokens with claims that allow an app client for a reporting system to only read data while allowing an app client for a data processing service to both read and modify data. This allows customers to streamline authentication by embedding custom authorization attributes directly into access tokens during the token issuance process.
Access token customization for M2M authorization is available to Amazon Cognito customers using Essentials or Plus tiers in all AWS Regions where Cognito is available, except the AWS GovCloud (US) Regions. To learn more, refer to the developer guide.
