AWS CodeBuild managed images now support Node 22, Python 3.13, and Go 1.23. These new runtime versions are available in Linux x86, Arm, Windows and macOS platforms. AWS CodeBuild is a fully managed continuous integration service that compiles source code, runs tests, and produces software packages ready for deployment.
For CodeBuild managed images based on Linux, you can specify a runtime of your choice in the runtime-versions section of your buildspec file. You can select specific major and minor versions supported by CodeBuild, or define a custom runtime version. Additionally with this release, we added commonly used tools that are available in GitHub Actions environments to better support customers using CodeBuild as a self-hosted runner option.
The updated images are available in all regions where CodeBuild is offered. For more information about the AWS Regions where CodeBuild is available, see the AWS Regions page.
To learn more about docker images and runtime versions provided by CodeBuild, please visit our documentation or our image repository. To learn more about how to get started with CodeBuild, visit the AWS CodeBuild product page.
