Serverless queue processors like AWS Lambda often exist in architectures where they pull messages from queues such as Amazon Simple Queue Service (Amazon SQS) and interact with downstream services or external APIs in a distributed architecture. Robust retry approaches are necessary to provide reliable message processing due to the susceptibility of these downstream services to short-term outages or throttling. This often requires implementing special retry logic with features like dead-letter queues (DLQs) and exponential backoff to handle these cases gracefully, making sure that the downstream systems don’t get overwhelmed by too many retries.
In this post, we propose a solution that handles serverless retries when the workflow’s state isn’t managed by an additional service.
Solution overview
Some custom retry logic is required when Lambda functions interact with downstream services after consuming messages from SQS queues. This strategy involves the usage of Amazon EventBridge Scheduler and code in Lambda. The core concept is to implement a robust retry mechanism for handling failed message processing attempts using an EventBridge scheduler. When a Lambda function encounters a problem while processing a message, it triggers a specific error. Upon catching this error in a catch block, the function generates an EventBridge schedule. As a result, the message is sent back to the SQS queue and will be available for processing again at a specified future time.
In this approach, the retry mechanism can have a fine-grained level of control over the retry timing that might also support various techniques, including exponential backoff and linear retry intervals. This approach separates the retry logic from the code to process the message itself, making the Lambda function performant. Along with handling messages when all retries are exhausted, this solution interfaces with a DLQ to keep such messages separate from the main queue.
The following diagram illustrates the solution architecture.
The error handling and retry choice logic in the Lambda function code form the basis for how this custom retry mechanism is implemented. If there is an error while processing the message, the function raises a specific exception. Raising the exception then initiates the retry flow. A try-catch block catches this exception and calls a function that interfaces with the EventBridge Scheduler API to build a custom schedule. To configure the schedule, we include the destination SQS queue and the intended timestamp when the message is meant to be retried. We can change the delay with some code modifications depending on a number of parameters, such as error type, number of prior retries, or other custom backoff schemes.
As part of this approach, we use SQS message attributes for idempotency and to track retries. On each retry, the function adds the new timestamp to an array in the message body. If the function consumes the message more times than the maximum retry limit (determined by the array of retry attempts) it sends the message to the DLQ without rescheduling.
The solution also involves the integration of a DLQ so that it doesn’t keep messages in the main processing queue and be retried forever. The Lambda function will register messages with the DLQ in case of either exceeding the maximum retry limit or when certain error scenarios require it to stop early. This queue keeps all communications that have failed until such a time they can be manually reviewed, reprocessed, or even corrected.
Considerations and best practices
There are a few key factors to keep in mind while putting this custom retry system into practice. One aspect is handling partial failures, that is, processing where only part of the steps are complete. In such cases, we could use some form of compensating action or rollback to maintain consistency in data and avoid discrepancies downstream of the queue consumer.
Another crucial factor is controlling retry limits. Although the system design allows for variable retry limits, we must balance resource usage and resilience. Too many retries might cause higher costs and lead to slowdowns or service degradation. That is why we recommend that appropriate retry limits are set, considering probable failure rates, SLAs, and business consequences of failures.
We must also consider that EventBridge Scheduler has a granularity of 1 minute, and there is additional latency between the queue and the function, so the mechanism will not be completely precise. In principle, the scheduler sets the minimum time before which the message can be processed, making sure the Lambda function adheres to the rate limits at a minimum. This could also result in additional delays, so the mechanism would need to be adjusted for time-sensitive applications to account for these delays.
Because the solution might deal with variable volumes of messages and processing loads, scaling issues are also important. For example, the Lambda concurrency and retention period for the queue represent resource configurations we should monitor and adjust for optimal performance and cost.
Finally, we need to consider security as part of the solution. If the downstream service runs in a virtual private cloud (VPC), we would also need to place the Lambda function in the VPC. In this case, we would need to access EventBridge Scheduler through AWS PrivateLink, which enables secure and performant access to services from within a VPC.
Additionally, it is important to implement the AWS Identity and Access Management (IAM) roles (mainly the Lambda function role) with the principal of least privilege, which gives it access to create the EventBridge schedule (and iam:PassRole to give the scheduler the required permissions) as well as pass the scheduler’s IAM role to it. The scheduler’s role only needs permission to place a message into the source queue. We also need to give the function access to place a message in the DLQ and receive messages from the source queue.
Monitoring and troubleshooting
The custom retry mechanism demands efficient monitoring and debugging. With that in mind, we might view various behaviors of the system and identify potential problems by using Amazon CloudWatch logs and metrics.
The number of invocations of Lambda functions, related error rates, runtimes, and use of DLQ are the key indicators that we should monitor. It would be worth setting up alarms in CloudWatch to send an alert or initiate automated actions when the Lambda function’s metrics surpass certain predetermined thresholds. By doing this, we proactively detect and resolve certain issues pertaining to the function.
Also, we can examine logs of the Lambda function for certain error situations, retry patterns, or problems with the downstream services or with the retry logic itself. We can place logging lines judiciously in the function code to record pertinent information, including message attributes, retry attempts, and error details.
Future enhancements
There are some improvements we could consider to enhance the capabilities and flexibility of the suggested approach even further, which provides a foundation to customize retry mechanisms.
A possible improvement would be to introduce dynamic retry intervals depending on the conditions of a downstream service or kinds of errors. Instead of being based on predefined backoff schemes, the system might dynamically adjust the retry intervals based on specific error types detected or in-service health monitoring in real time. This concept’s principal disadvantage is additional complexity, which might cause the failure of the retry process itself.
Another potential enhancement is the integration of the system with external configuration services such as Amazon DynamoDB or Parameter Store, a capability of AWS Systems Manager. That way, we can handle the retry configurations centrally and dynamically to provide ease of maintenance and modification in retry strategies without having to redeploy the Lambda function code.
It would also be possible to build in advanced error analysis and reporting into the system. The system would then have the potential to provide key insights for root cause analysis and proactive remediation through comprehensive reporting, patterns of errors analyzed, and failures correlated with downstream service health.
It is often challenging to build scalable, robust serverless applications that might need to talk with external services. However, the proposed solution using Lambda, Amazon SQS, and EventBridge Scheduler brings a simple yet effective solution to implement customized retry mechanisms. It gives the developer fine-grained control over the retry interval, supports scenarios such as exponential backoff, and works seamlessly with DLQs for persisting failures and EventBridge Scheduler for delayed retries of messages. The mechanism can also be reused more broadly for stateless queue consumers, not only for Lambda functions. This pattern enables developers to implement robust, fault-tolerant serverless systems that handle disruptions in downstream services gracefully.
About the Author
