Posted February 6Feb 6 Cost Optimization Hub now supports idle EC2 Auto Scaling group recommendations and rightsizing recommendations for EC2 Auto Scaling groups with scaling policies and multiple instance types. It also allows you to easily filter and aggregate EC2 Auto Scaling group cost optimization opportunities separately from standalone EC2 instances, making it easier to identify EC2 Auto Scaling groups with the highest cost-saving opportunities. With this launch, you can view, consolidate, and prioritize cost optimization opportunities for EC2 Auto Scaling groups across your organization’s member accounts and AWS Regions through a single dashboard. Cost Optimization Hub helps you quantify estimated savings from these recommendations, taking into account your specific discounts, such as Reserved Instances and Savings Plans, enabling you to easily compare and prioritize recommendations. The new EC2 Auto Scaling group experience and recommendations are available in Cost Optimization Hub across all AWS Regions where Cost Optimization Hub and AWS Organizations are supported. View the full article
