AWS IAM Identity Center now provides improved error messages to simplify troubleshooting when syncing users and groups. You can also build automated monitoring and auditing for these errors using the AWS CloudTrail logs.
IAM Identity Center helps you securely connect your workforce identities and manage their access centrally across AWS accounts and applications. With improved error messaging, IAM Identity Center provides actionable information to troubleshoot provisioning issues as you sync your users and groups using SCIM or configurable AD sync. CloudTrail logs enable automated monitoring of synchronization processes and provide audit trails of provisioning issues.
IAM Identity Center is available at no additional cost in all AWS Regions where it is supported. To learn more, see the AWS IAM Identity Center User Guide.
