Introducing generative AI troubleshooting for Apache Spark in AWS Glue (preview)
Organizations run millions of Apache Spark applications each month to prepare, move, and process their data for analytics and machine learning (ML). Building and maintaining these Spark applications is an iterative process, where developers spend significant time testing and troubleshooting their code. During development, data engineers often spend hours sifting through log files, analyzing execution plans, and making configuration changes to resolve issues. This process becomes even more challenging in production environments due to the distributed nature of Spark, its in-memory processing model, and the multitude of configuration options available. Troubleshooting these production issues requires extensive analysis of logs and metrics, often leading to extended downtimes and delayed insights from critical data pipelines.
Today, we are excited to announce the preview of generative AI troubleshooting for Spark in AWS Glue. This is a new capability that enables data engineers and scientists to quickly identify and resolve issues in their Spark applications. This feature uses ML and generative AI technologies to provide automated root cause analysis for failed Spark applications, along with actionable recommendations and remediation steps. This post demonstrates how you can debug your Spark applications with generative AI troubleshooting.
How generative AI troubleshooting for Spark works
For Spark jobs, the troubleshooting feature analyzes job metadata, metrics and logs associated with the error signature of your job to generates a comprehensive root cause analysis. You can initiate the troubleshooting and optimization process with a single click on the AWS Glue console. With this feature, you can reduce your mean time to resolution from days to minutes, optimize your Spark applications for cost and performance, and focus more on deriving value from your data.
Manually debugging Spark applications can get challenging for data engineers and ETL developers due to a few different reasons:
  • Extensive connectivity and configuration options to a variety of resources with Spark while makes it a popular data processing platform, often makes it challenging to root cause issues when configurations are not correct, especially related to resource setup (S3 bucket, databases, partitions, resolved columns) and access permissions (roles and keys).
  • Spark’s in-memory processing model and distributed partitioning of datasets across its workers while good for parallelism, often make it difficult for users to identify root cause of failures resulting from resource exhaustion issues like out of memory and disk exceptions.
  • Lazy evaluation of Spark transformations while good for performance, makes it challenging to accurately and quickly identify the application code and logic which caused the failure from the distributed logs and metrics emitted from different executors.
Let’s look at a few common and complex Spark troubleshooting scenarios where Generative AI Troubleshooting for Spark can save hours of manual debugging time required to deep dive and come up with the exact root cause.
Resource setup or access errors
Spark applications allows to integrate data from a variety of resources like datasets with several partitions and columns on S3 buckets and Data Catalog tables, use the associated job IAM roles and KMS keys for correct permissions to access these resources, and require these resources to exist and be available in the right regions and locations referenced by their identifiers. Users can mis-configure their applications that result in errors requiring deep dive into the logs to understand the root cause being a resource setup or permission issue.
Manual RCA: Failure reason and Spark application Logs
Following example shows the failure reason for such a common setup issue for S3 buckets in a production job run. The failure reason coming from Spark does not help understand the root cause or the line of code that needs to be inspected for fixing it.
Exception in User Class: org.apache.spark.SparkException : Job aborted due to stage failure: Task 0 in stage 0.0 failed 4 times, most recent failure: Lost task 0.3 in stage 0.0 (TID 3) (172.36.245.14 executor 1): com.amazonaws.services.glue.util.NonFatalException: Error opening file:
After deep diving into the logs of one of the many distributed Spark executors, it becomes clear that the error was caused due to a S3 bucket not existing, however the error stack trace is usually quite long and truncated to understand the precise root cause and location within Spark application where the fix is needed.
Caused by: java.io.IOException: com.amazon.ws.emr.hadoop.fs.shaded.com.amazonaws.services.s3.model.AmazonS3Exception: The specified bucket does not exist (Service: Amazon S3; Status Code: 404; Error Code: NoSuchBucket; Request ID: 80MTEVF2RM7ZYAN9; S3 Extended Request ID: AzRz5f/Amtcs/QatfTvDqU0vgSu5+v7zNIZwcjUn4um5iX3JzExd3a3BkAXGwn/5oYl7hOXRBeo=; Proxy: null), S3 Extended Request ID: AzRz5f/Amtcs/QatfTvDqU0vgSu5+v7zNIZwcjUn4um5iX3JzExd3a3BkAXGwn/5oYl7hOXRBeo=
at com.amazon.ws.emr.hadoop.fs.s3n.Jets3tNativeFileSystemStore.list(Jets3tNativeFileSystemStore.java:423)
at com.amazon.ws.emr.hadoop.fs.s3n.Jets3tNativeFileSystemStore.isFolderUsingFolderObject(Jets3tNativeFileSystemStore.java:249)
at com.amazon.ws.emr.hadoop.fs.s3n.Jets3tNativeFileSystemStore.isFolder(Jets3tNativeFileSystemStore.java:212)
at com.amazon.ws.emr.hadoop.fs.s3n.S3NativeFileSystem.getFileStatus(S3NativeFileSystem.java:518)
at com.amazon.ws.emr.hadoop.fs.s3n.S3NativeFileSystem.open(S3NativeFileSystem.java:935)
at com.amazon.ws.emr.hadoop.fs.s3n.S3NativeFileSystem.open(S3NativeFileSystem.java:927)
at org.apache.hadoop.fs.FileSystem.open(FileSystem.java:983)
at com.amazon.ws.emr.hadoop.fs.EmrFileSystem.open(EmrFileSystem.java:197)
at com.amazonaws.services.glue.hadoop.TapeHadoopRecordReaderSplittable.initialize(TapeHadoopRecordReaderSplittable.scala:168)
... 29 more
With Generative AI Spark Troubleshooting: RCA and Recommendations
With Spark Troubleshooting, you simply click the Troubleshooting analysis button on your failed job run, and the service analyzes the debug artifacts of your failed job to identify the root cause analysis along with the line number in your Spark application that you can inspect to further resolve the issue.
Spark Out of Memory Errors
Let’s take a common but relatively complex error that requires significant manual analysis to conclude its because of a Spark job running out of memory on Spark driver (master node) or one of the distributed Spark executors. Usually, troubleshooting requires an experienced data engineer to manually go over the following steps to identify the root cause.
  • Search through Spark driver logs to find the exact error message
  • Navigate to the Spark UI to analyze memory usage patterns
  • Review executor metrics to understand memory pressure
  • Analyze the code to identify memory-intensive operations
This process often takes hours because the failure reason from Spark is usually not challenging to understand that it was a out of memory issue on the Spark driver and what is the remedy to fix it.
Following example shows the failure reason for the error.
Py4JJavaError: An error occurred while calling o4138.collectToPython. java.lang.StackOverflowError
Spark driver logs require extensive search to find the exact error message. In this case, the error stack trace consisted of more than hundred function calls and is challenging to understand the precise root cause as the Spark application terminated abruptly.
py4j.protocol.Py4JJavaError: An error occurred while calling o4138.collectToPython.
: java.lang.StackOverflowError
 at org.apache.spark.sql.catalyst.trees.TreeNode$$Lambda$1942/131413145.get$Lambda(Unknown Source)
 at org.apache.spark.sql.catalyst.trees.TreeNode.$anonfun$mapChildren$1(TreeNode.scala:798)
 at org.apache.spark.sql.catalyst.trees.TreeNode.mapProductIterator(TreeNode.scala:459)
 at org.apache.spark.sql.catalyst.trees.TreeNode.mapChildren(TreeNode.scala:781)
 at org.apache.spark.sql.catalyst.trees.TreeNode.clone(TreeNode.scala:881)
 at org.apache.spark.sql.catalyst.plans.logical.LogicalPlan.org$apache$spark$sql$catalyst$plans$logical$AnalysisHelper$$super$clone(LogicalPlan.scala:30)
 at org.apache.spark.sql.catalyst.plans.logical.AnalysisHelper.clone(AnalysisHelper.scala:295)
 at org.apache.spark.sql.catalyst.plans.logical.AnalysisHelper.clone$(AnalysisHelper.scala:294)
 at org.apache.spark.sql.catalyst.plans.logical.LogicalPlan.clone(LogicalPlan.scala:30)
 at org.apache.spark.sql.catalyst.trees.TreeNode.$anonfun$clone$1(TreeNode.scala:881)
 at org.apache.spark.sql.catalyst.trees.TreeNode.applyFunctionIfChanged$1(TreeNode.scala:747)
 at org.apache.spark.sql.catalyst.trees.TreeNode.$anonfun$mapChildren$1(TreeNode.scala:783)
 ... repeated several times with hundreds of function calls
With Spark Troubleshooting, you can click the Troubleshooting analysis button on your failed job run and get a detailed root cause analysis with the line of code which you can inspect, and also recommendations on best practices to optimize your Spark application for fixing the problem.
Spark Out of Disk Errors
Another complex error pattern with Spark is when it runs out of disk storage on one of the many Spark executors in the Spark application. Similar to Spark OOM exceptions, manual troubleshooting requires extensive deep dive into distributed executor logs and metrics to understand the root cause and identify the application logic or code causing the error due to Spark’s lazy execution of its transformations.
Manual RCA: Failure Reason and Spark application Logs
The associated failure reason and error stack trace in the application logs is again quiet long requiring the user to gather more insights from Spark UI and Spark metrics to identify the root cause and identify the resolution.
An error occurred while calling o115.parquet. No space left on device
py4j.protocol.Py4JJavaError: An error occurred while calling o115.parquet.
: org.apache.spark.SparkException: Job aborted.
 at org.apache.spark.sql.errors.QueryExecutionErrors$.jobAbortedError(QueryExecutionErrors.scala:638)
 at org.apache.spark.sql.execution.datasources.FileFormatWriter$.write(FileFormatWriter.scala:279)
 at org.apache.spark.sql.execution.datasources.InsertIntoHadoopFsRelationCommand.run(InsertIntoHadoopFsRelationCommand.scala:193)
 at org.apache.spark.sql.execution.command.DataWritingCommandExec.sideEffectResult$lzycompute(commands.scala:113)
 at org.apache.spark.sql.execution.command.DataWritingCommandExec.sideEffectResult(commands.scala:111)
 at org.apache.spark.sql.execution.command.DataWritingCommandExec.executeCollect(commands.scala:125)
With Spark Troubleshooting, it provides the RCA and the line number of code in the script where the data shuffle operation was lazily evaluated by Spark. It also points to best practices guide for optimizing the shuffle or wide transforms or using S3 shuffle plugin on AWS Glue.
Debug AWS Glue for Spark jobs
To use this troubleshooting feature for your failed job runs, complete following:
  1. On the AWS Glue console, choose ETL jobs in the navigation pane.
  2. Choose your job.
  3. On the Runs tab, choose your failed job run.
  4. Choose Troubleshoot with AI to start the analysis.
  5. You will be redirected to the Troubleshooting analysis tab with generated analysis.
You will see Root Cause Analysis and Recommendations sections.
The service analyzes your job’s debug artifacts and provide the results. Let’s look at a real example of how this works in practice.
We show below an end-to-end example where Spark Troubleshooting helps a user with identification of the root cause for a resource setup issue and help fix the job to resolve the error.
Considerations
During preview, the service focuses on common Spark errors like resource setup and access issues, out of memory exceptions on Spark driver and executors, out of disk exceptions on Spark executors, and will clearly indicate when an error type is not yet supported. Your jobs must run on AWS Glue version 4.0.
The preview is available at no additional charge in all AWS commercial Regions where AWS Glue is available. When you use this capability, any validation runs triggered by you to test proposed solutions will be charged according to the standard AWS Glue pricing.
This post demonstrated how generative AI troubleshooting for Spark in AWS Glue helps your day-to-day Spark application debugging. It simplifies the debugging process for your Spark applications by using generative AI to automatically identify the root cause of failures and provides actionable recommendations to resolve the issues.
To learn more about this new troubleshooting feature for Spark, please visit Troubleshooting Spark jobs with AI.
A special thanks to everyone who contributed to the launch of generative AI troubleshooting for Apache Spark in AWS Glue: Japson Jeyasekaran, Rahul Sharma, Mukul Prasad, Weijing Cai, Jeremy Samuel, Hirva Patel, Martin Ma, Layth Yassin, Kartik Panjabi, Maya Patwardhan, Anshi Shrivastava, Henry Caballero Corzo, Rohit Das, Peter Tsai, Daniel Greenberg, McCall Peltier, Takashi Onikura, Tomohiro Tanaka, Sotaro Hikita, Chiho Sugimoto, Yukiko Iwazumi, Gyan Radhakrishnan, Victor Pleikis, Sriram Ramarathnam, Matt Sampson, Brian Ross, Alexandra Tello, Andrew King, Joseph Barlan, Daiyan Alamgir, Ranu Shah, Adam Rohrscheib, Nitin Bahadur, Santosh Chandrachood, Matt Su, Kinshuk Pahare, and William Vambenepe.
About the Authors
Noritaka-Sekiyama.jpgNoritaka Sekiyama is a Principal Big Data Architect on the AWS Glue team. He is responsible for building software artifacts to help customers. In his spare time, he enjoys cycling with his road bike.
vkajjam.jpegVishal Kajjam is a Software Development Engineer on the AWS Glue team. He is passionate about distributed computing and using ML/AI for designing and building end-to-end solutions to address customers’ data integration needs. In his spare time, he enjoys spending time with family and friends.
shubham.jpgShubham Mehta is a Senior Product Manager at AWS Analytics. He leads generative AI feature development across services such as AWS Glue, Amazon EMR, and Amazon MWAA, using AI/ML to simplify and enhance the experience of data practitioners building data applications on AWS.
wetang.jpgWei Tang is a Software Development Engineer on the AWS Glue team. She is strong developer with deep interests in solving recurring customer problems with distributed systems and AI/ML.
Xiaorun-Yu.jpgXiaoRun Yu is a Software Development Engineer on the AWS Glue team. He is working on building new features for AWS Glue to help customers. Outside of work, Xiaorun enjoys exploring new places in the Bay Area.
jzych.jpgJake Zych is a Software Development Engineer on the AWS Glue team. He has deep interest in distributed systems and machine learning. In his spare time, Jake likes to create video content and play board games.
savio.pngSavio Dsouza is a Software Development Manager on the AWS Glue team. His team works on generative AI applications for the data integration domain and distributed systems for efficiently managing data processing on AWS and optimizing Apache Spark for performance and reliability.
Mohit-Saxena.pngMohit Saxena is a Senior Software Development Manager on the AWS Glue and Amazon EMR team. His team focuses on building distributed systems to enable customers with simple-to-use interfaces and AI-driven capabilities to efficiently transform petabytes of data across data lakes on Amazon S3, and databases and data warehouses on the cloud.
