Posted October 8, 20204 yr The upcoming Module feature for Azure Bicep really enhances the new ARM Template alternative language in a way that ARM JSON never did. Using Azure Bicep Modules you can easily create reusable bicep code that will eliminate copy/paste of bicep code across multiple deployment projects. Azure Bicep Modules do not require any special syntax, and […] The article Creating Azure Bicep Modules for Code Reuse appeared first on Build5Nines. View the full article
