AWS announces general availability of Amazon DynamoDB zero-ETL integration with Amazon Redshift
Amazon DynamoDB zero-ETL integration with Amazon Redshift is now generally available, enabling customers to run high-performance analytics on their DynamoDB data in Amazon Redshift with no impact on production workloads running on DynamoDB. As data is written into a DynamoDB table, it is seamlessly made available in Amazon Redshift, eliminating the need for customers to build and maintain complex data pipelines for performing extract, transform, and load (ETL) operations. You can create zero-ETL integration on a Amazon Redshift Serverless workgroup or Amazon Redshift provisioned cluster using RA3 instance types.
Zero-ETL integrations help you derive holistic insights across many applications, break data silos in your organization, and gain significant cost savings and operational efficiencies. Now you can run enhanced analysis on your DynamoDB data with the rich capabilities of Amazon Redshift, such as high performance SQL, built-in ML and Spark integrations, materialized views with automatic and incremental refresh, data sharing, and ability to join data across multiple data stores and data lakes.
Amazon DynamoDB zero-ETL integration with Amazon Redshift is available in commercial regions and the AWS GovCloud (US) Regions. You can create and manage integrations using either the AWS Management Console, the AWS Command Line Interface (CLI), or the Amazon Redshift APIs.
To learn more, visit the getting started guides for DynamoDB and Amazon Redshift.
