Use AWS Lambda Extensions to Securely Retrieve Secrets From HashiCorp Vault
Hashicorp
 Share
We are excited to announce the public preview of a HashiCorp Vault AWS Lambda extension, utilizing the newly announced AWS Lambda Extensions API (also in public preview) to securely retrieve secrets from HashiCorp Vault.
Practitioners that have standardized on HashiCorp Vault for secrets management and AWS Lambda as their serverless compute environment no longer have to make their Lambda functions Vault aware. The extension will retrieve the specified secret from a Vault cluster and present it to the Lambda function.
"Hundreds of thousands of customers use AWS Lambda to run their applications - all they need to do is supply the code,” says Dhruv Sood, Sr. Product Manager, AWS Lambda, Amazon Web Services, Inc. "The HashiCorp Vault extension for AWS Lambda makes it easy for operators to manage their secrets and make them available for developers to use within their application code.”
Link to comment
Share on other sites
  Only 75 emoji are allowed.
 Share
  • Create New...
