Amazon OpenSearch Serverless is a serverless version of Amazon OpenSearch Service, a fully managed open search and analytics platform. On Amazon OpenSearch Service you can run petabyte-scale search and analytics workloads without the heavy lifting of managing the underlying OpenSearch Service clusters and Amazon OpenSearch Serverless supports workloads up to 30TB of data for time-series collections. Amazon OpenSearch Serverless provides an installation of OpenSearch Dashboards with every collection created.
The network configuration for an OpenSearch Serverless collection controls how the collection can be accessed over the network. You have the option to make the collection publicly accessible over the internet from any network, or to restrict access to the collection only privately through OpenSearch Serverless-managed virtual private cloud (VPC) endpoints. This network access setting can be defined separately for the collection’s OpenSearch endpoint (used for data operations) and its corresponding OpenSearch Dashboards endpoint (used for visualizing and analyzing data). In this post, we work with a publicly accessible OpenSearch Serverless collection.
SAML enables users to access multiple applications or services with a single set of credentials, eliminating the need for separate logins for each application or service. This improves the user experience and reduces the overhead of managing multiple credentials. We provide SAML authentication for OpenSearch Serverless. With this you can use your existing identity provider (IdP) to offer single sign-on (SSO) for the OpenSearch Dashboards endpoints of serverless collections. OpenSearch Serverless supports IdPs that adhere to the SAML 2.0 standard, including services like AWS IAM Identity Center, Okta, Keycloak, Active Directory Federation Services (AD FS), and Auth0. This SAML authentication mechanism is solely intended for accessing the OpenSearch Dashboards interface through a web browser.
In this post, we show you how to configure SAML authentication for controlling access to public OpenSearch Dashboards using Keycloak as an IdP.
Solution overview
The following diagram illustrates a sample architecture of a solution that allows users to authenticate to OpenSearch Dashboards using SSO with Keycloak.
The sign-in flow includes the following steps:
  1. A user accesses OpenSearch Dashboards in a browser and chooses an IdP from the list.
  2. OpenSearch Serverless generates a SAML authentication request.
  3. OpenSearch Service redirects the request back to the browser.
  4. The browser redirects the user to the selected IdP (Keycloak). Keycloak provides a login page, where users can provide their login credentials.
  5. If authentication was successful, Keycloak returns the SAML response to the browser.
  6. The SAML assertions is sent back to OpenSearch Serverless.
  7. OpenSearch Serverless validates the SAML assertion, and logs the user in to OpenSearch Dashboards.
Prerequisites
To get started, you should have the following prerequisites:
  1. An active OpenSearch Serverless collection
  2. A working Keycloak server (on premises or in the cloud)
  3. The following AWS Identity and Access Management (IAM) permissions to configure SAML authentication in OpenSearch Serverless:
    • aoss:CreateSecurityConfig – Create a SAML provider.
    • aoss:ListSecurityConfig – List all SAML providers in the current account.
    • aoss:GetSecurityConfig – View SAML provider information.
    • aoss:UpdateSecurityConfig – Modify a given SAML provider configuration, including the XML metadata.
    • aoss:DeleteSecurityConfig – Delete a SAML provider.
Create and configure a client in Keycloak
Complete the following steps to create your Keycloak client:
  1. Login to your Keycloak admin page.
  2. In the navigation pane, choose Client.
  3. Choose Create client
  4. For Client type, choose SAML.
  5. For Client ID enter aws:opensearch:AWS_ACCOUNT_ID, where AWS_ACCOUNT_ID is your AWS account ID.
  6. Enter a name and description for your client.
  7. Choose Next.
  8. For Valid redirect URIs, enter the address of the assertion consumer service (ACS), where REGION is the AWS Region in which you have created the OpenSearch Serverless collection.
  9. For Master SAML Processing URL, also enter the preceding ACS address.
  10. Complete your client creation.
  11. After you create the client, you have to disable the Signing keys config setting, because OpenSearch Serverless signed and encrypted requests are not supported. For more details, refer to Considerations.BDB-3367-005-1024x502.png
  12. After you have created the client and disabled the client signature, you can export the SAML 2.0 IdP Metadata by choosing the link on the Realm settings page. You need this metadata, when you create the SAML provider in OpenSearch Serverless.
When your OpenSearch Serverless collection is active, you then create a SAML provider. This SAML provider can be assigned to any collection in the same Region. Complete the following steps:
  1. On the OpenSearch Service console, under Serverless in the navigation pane, choose SAML authentication under Security.
  2. Choose Create SAML provider.
  3. Enter a name and description for your SAML provider.
  4. Enter the IdP metadata you downloaded earlier from Keycloak.
  5. Under Additional settings, you can optionally add custom user ID and group attributes (for this example, we leave this empty).
  6. Choose Create a SAML provider.
You have now configured a SAML provider for OpenSearch Serverless. Next, you configure the data access policy for accessing collections.
Create a data access policy
After you have configured SAML provider, you have to create data access policies for OpenSearch Serverless to allow access to the users.
  1. On the OpenSearch Service console, under Serverless in the navigation pane, choose Data access policies under Security.
  2. Choose Create access policy.
  3. Enter a name and optional description for your access policy.
  4. For Policy definition method, select Visual editor.
  5. For Rule name, enter a name.
  6. Under Select principals, for Add principals, choose SAML users and groups.
  7. For SAML provider name, choose the provider you created before.
  8. Choose Save.
  9. Specify the user or group in the format user/USERNAME or group/GROUPNAME. The value of the USERNAME or GROUPNAME should match the value you specified in Keycloak for user-/groupname.
  10. Choose Save.
  11. Choose Grant to grant permissions to resources.
  12. In the Grant resources and permissions section, you can specify access you want to provide for a given user at the collection level, and also at the index pattern level.
    For more information about how to set up more granular access for your users, refer to Supported OpenSearch API operations and permissions and Supported policy permissions.
  13. Choose Save.
  14. You can create additional rules if needed.
  15. Choose Create to create the data access policy.
Now, you have data access policy that will allow users to access the OpenSearch Dashboards and perform the allowed actions there.
Access the OpenSearch Dashboards
Complete the following steps to sign in to the OpenSearch Dashboards:
  1. On the OpenSearch Service console, under Serverless in the navigation pane, choose Dashboard.
  2. In the Collection section, locate your collection and choose Dashboard.
    The OpenSearch login page will open in a new browser tab.
  3. Choose your IdP provider on the dropdown menu and choose Login.
    You will be redirected to the Keycloak sign-in page.
  4. Log in with your SSO credentials.
After a successful login, you will be redirected to OpenSearch Dashboards, and you can perform the actions allowed by the data access policy.
You have successfully federated OpenSearch Dashboards with Keycloak as an IdP.
Cleaning up
When you’re done with this solution, delete the resources you created if you no longer need them.
  1. Delete your OpenSearch Serverless collection.
  2. Delete your data access policy.
  3. Delete the SAML provider.
In this post, we demonstrated how to set up Keycloak as an IdP to access an OpenSearch Serverless dashboard using SAML authentication. For more details, refer to SAML authentication for Amazon OpenSearch Serverless
About the Author
arpadcs.jpegArpad Csoke is a Solutions Architect at Amazon Web Services. His responsibilities include helping large enterprise customers understand and utilize the AWS environment, acting as a technical consultant to contribute to solving their issues.
