Data Exports for Cost Optimization Hub now enables customers to export their cost optimization recommendations to Amazon S3. Cost Optimization Hub recommendations are consolidated from over 15 types of AWS cost optimization recommendations, such as EC2 instance rightsizing, Graviton migration, and Savings Plan purchases across their AWS accounts and AWS Regions. Exports are delivered on a daily basis to Amazon S3 in Parquet or CSV format.
With Data Exports for Cost Optimization Hub, customers receive their recommendations in easy-to-ingest data files, which simplifies creating reports or dashboards. Customers can apply the same filters and preferences to their exports that they use in Cost Optimization Hub to deduplicate savings. Customers can also control the data included in their export using basic SQL column selections and row filters. Data Exports for Cost Optimization Hub makes it easy for customers to bring their recommendation data into analytics and BI tools for tracking, prioritizing, and sharing savings opportunities with key stakeholders.
Data Exports for Cost Optimization Hub is available in the US East (N. Virginia) Region, but include recommendations for all AWS Regions, except AWS GovCloud (US) Regions and AWS China (Beijing and Ningxia) Regions.
Learn more about Data Exports for Cost Optimization Hub exports in the Data Exports User Guide and in the Data Exports product details page. You can also learn more about Cost Optimization Hub in the Cost Optimization Hub User Guide. Get started by visiting the “Data Exports” or “Cost Optimization Hub” features in the AWS Billing and Cost Management console and creating an export of the “Cost Optimization Recommendations” table.
