Amazon QuickSight now supports the ability to sort by multiple columns in Tables. This allows both authors and readers to sort by two or more columns simultaneously in a nested fashion (e.g., first by column A, then B, then C) using the new sorting pop over. They can add, remove, reorder and reset sort on a table. Readers can also perform multi column sort using hidden and off visual field as defined by the author or opt for single column sort from column header context menu as well. For more details refer to documentation.
