Being a cross-platform document-first NoSQL database program, MongoDB operates on JSON-like documents. On the other hand, JDBC is a Java application programming interface (API) used while executing queries in association with the database. Using JDBC, you can seamlessly access any data source from any relational database in spreadsheet format or a flat file. In fact, […]
