Posted May 5, 2024May 5 At first this sounds crazy, but Azure DevOps Pipelines are actually a Serverless compute engine. When you compare it to other Azure cloud services, it’s sort of a mixture of the features of Azure Functions and Azure Logic Apps mixed with Git source control integration. At first glance, it might seem a bit far-fetched to […] The article Use Azure DevOps Pipelines as a Serverless Compute Engine appeared first on Build5Nines. View the full article
